Stators
- Cturbo
Stators
I replaced the original stator assembly of my 1992 KDX with a stator from a 2005 model. I know the part # are different but they look exactly the same except for the timing marks. I am missing something ?
It has spark, but doesn't start.
1992 KDX 200
2004 KLX 110
2006 SMR 510
2004 KLX 110
2006 SMR 510
- Cturbo
At least now I know it has been done. I am still using the stock 1992 flywheel. I changed the timing to the center mark of the stator. Still no start and a constant wet spark plug sindrome. When the plugs are dry it shows a good spark. I have this bike since new and worked out the worst river drowning you could imagine with some kiking but nothing like this.
1992 KDX 200
2004 KLX 110
2006 SMR 510
2004 KLX 110
2006 SMR 510
Try bumping it?
- Cturbo
Is timing that critical? At least it should sputter or kick back and I did not get any on the three positions. I can put a timing light on it but the flywheel don't have a mark to match the one on the case and in the service manual there is no mention of this procedure.
1992 KDX 200
2004 KLX 110
2006 SMR 510
2004 KLX 110
2006 SMR 510
- ss109
- Has thanked: 34 times
- Been thanked: 58 times
Yes, it is extremely critical.Cturbo wrote:Is timing that critical?
Not necessarily. It depends on if the timing is that far out. BTW, have you tried a fresh plug?Cturbo wrote:At least it should sputter or kick back and I did not get any on the three positions.
- Cturbo
The three timing marks on the stator seems to be in a different place by a couple of degrees in comparasion with the stock one. It is my guess that they calibrate the marks once the coil is mounted on the stator to compensate for stator casting or other variances. A poorly made stator will move your timing enough to cause probems. I know this from a previous experience with an aftermarket stator. I am using new plugs. When they get wet, I clean them with solvent and test them on another bike. That make me notice that the KDX has a weaker spark than my other bikes. I can't jump a spark more than 3 mm by kick. I don't remember it been so weak before.
1992 KDX 200
2004 KLX 110
2006 SMR 510
2004 KLX 110
2006 SMR 510
- Cturbo
I tried anoter coil and the spark still week. Tested the Cdi with a multimeter and the readings were all wrong. It was reading ok a year ago when I tested. I know what has been said of the good reliability of the KDX cdi on this site, but there is some logic on the way the bike is behaving. Is there an alternative beside a old used or old new stock one? Will an H series cdi work?
1992 KDX 200
2004 KLX 110
2006 SMR 510
2004 KLX 110
2006 SMR 510
Glad you got it sorted!
