run 1993 kdx 200 without powervlaves
tydev95
Post by tydev95 »
i can feel a couple of then, but just barely.
kdxmaniac
Post by kdxmaniac »
you can more than likely hone it and be fine............put a new piston{weisco} and you sould be good to go.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
tydev95
Post by tydev95 »
thanks, should i get it honed at a shop or use a scotch brite pad?
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Scotch Brite... a shop hone will ruin the plating.
kdxmaniac
Post by kdxmaniac »
Indawoods wrote:Scotch Brite... a shop hone will ruin the plating.
yep......never hone.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
Has thanked: 9 times
Been thanked: 17 times
kdxmaniac wrote:you can more than likely hone it and be fine............put a new piston{weisco} and you sould be good to go.
kdxmaniac wrote:>|<>QBB<
What? :|
tydev95
Post by tydev95 »
thanks, so all i have to do is get a left side powervalve, and the main one, and a top end kit
kdxmaniac
Post by kdxmaniac »
you can hone.....IF you have the right hone.....but most people do not use the right hone.......i know i said hone........but i got the thinking, everyone is not me and if you use one from a cheap auto parts store, chances are, you will ruin the plating, or hone to much. the 'safest' way is to use a scotchbright pad, and youll be good to go.
and to tydev95..........yes, just get a wiesco piston, and youll be good. the reason you want a forged piston is.......over time your bore will wear, and you need more clearence for a forged piston, hint, you already have you clearance... just trust me.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
lol. "just trust me"??
Did you sneak over there and mic his bore when we weren't looking? If not, it's pretty impressive if you can look at a fuzzy photo of a cylinder on the internet and say "hmmm... yep, that's worn out just about right for a wiseco"
Um, no. Not buying.
Hard to tell from the pics, but the bore looks worn. Have it measured before you go slapping a new top end in it. Excessive cylinder to piston clearance leads to piston slap, worn skirts, and eventually premature failure. I doubt kdxmaniac will foot the bill for those repairs simply because you chose to trust him.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Wiseco doesn't make oversize pistons. The tolerances are in the rings. A Wiseco will fit an A or D bore... doesn't matter.
kdxmaniac
Post by kdxmaniac »
juliend wrote:lol. "just trust me"??
Um, no. Not buying.
who the hell are you??? :lol: ............let me clear up something here...what is you daily job? and how many bikes do you own AND OR work on? i know what im talking about when it comes to engines. dont really care what you think........mister YOULIED......or whatever your name is.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
tydev95
Post by tydev95 »
assuming it's the stock bore, wouldn't a wiseco designed for the stock bore fit it? on the 220's people say to put in a wiseco even if the bike hasn't been run, due to the risk of the piston shattering. and thanks for the tip about the cylinder being too worn, i'll maybe take it to a local machine shop and have it measured.
kdxmaniac
Post by kdxmaniac »
you do relize this is a plated cylinder right? the plating is a few thousanths thick..........if it was wore "out" it woul be bare, peeling in the bore on the front and back where the skirts rubs..........and i never said anything about a overbore piston??? a stock bore forged piston has to have more clearence than a cast piston, because a forged piston swells when its warmed up, and if you dont have the clearence right, you will seize the piston........yes i know this. and also make sure you check your ring end gaps as well.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
tydev95
Post by tydev95 »
i get what kdxmaniac means, and if the bore is still in spec then i'll get a wiseco, i heard they are a lot better than cast pistons. and my dad's friend who's been an auto/motorcycle mechanic for 15 years said the lines on the cylinder walls were just ring marks.
kdxmaniac
Post by kdxmaniac »
tydev95 wrote:i get what kdxmaniac means, and if the bore is still in spec then i'll get a wiseco, i heard they are a lot better than cast pistons. and my dad's friend who's been an auto/motorcycle mechanic for 15 years said the lines on the cylinder walls were just ring marks.
go look at the [bore ar not to bore] forum.........look at the picks i put on there of cast pistons...........this is just a FEW of the cast pistons i have pulled out of bikes over the years.........now do you want a cast piston in YOUR bike????? all of these bikes{pics of pistons} got a weisco piston, and ran for years..........
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
tydev95
Post by tydev95 »
i think i'll get a forged piston :busted:
Mr. Wibbens
Post by Mr. Wibbens »
Lot of people run cast pistons without problems :roll:
kdxmaniac
Post by kdxmaniac »
if you get a weisco piston, ........the "hone" size is on the box.....your bike is a 66mm bore, so the cylinder bore should come up to around 66.0018 or 66.0020
if you get the shop to hone the cylinder, make sure they use a rigid or brush type hone........NEVER use a ball type hone on a plated cylinder.....or a rock type "cheap" store bought hone!
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
kdxmaniac
Post by kdxmaniac »
Mr. Wibbens wrote:Lot of people run cast pistons without problems :roll:
yea, alot of people dont have bikes with 240lbs compression? and 800hp boosted small blocks in there car either! try that with a cast piston........i not going to take a chance on a cast piston in a $12,000 engine in my car......and besides........why would you want to stick a cheap cast piston in your engine after spending all that money and time on your bike? i know your just kidding me anyway.."i hope".....about the cast pistons anyway? :? :grin:
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
tydev95
Post by tydev95 »
kdxmaniac, the site won't let me send pm's because i'm not a supporting member, but im from massachusetts.
