"If the steering is too tight, loosen the stem locknut a fraction of a turn; if the steering is too loose, tighten the locknut a fraction of a turn. Turn the locknut 1/8 turn at a time maximum."
That's it? No torque spec?
heckler wrote:did that KX500 fork just bolt right in? You needed a KX500 wheel too, right?
gregp wrote:If you have just replaced the steering head bearings, you may find that things "loosen up" a bit after the first ride as the bearings seat, so check them after you ride the bike.
I usually tighten the spanner nut up pretty tight, then back it off just a little bit.
gregp wrote:The lower bearing's outer race is particularly difficult to seat fully, unless you have a good driver. Sometimes the cone is not seated all the way either. Between the two, it is quite normal for this "loosening" to occur.
Like others have stated, be sure to loosen the fork clamps on the upper tree when you tighten up these bearings. Sometimes I will tap the upper tree with a soft mallet to make sure that things have found their home.
