This came from my 05 cylinder, I did the top end about 2 years ago, and it looks about the same shape as last time.
There was some carbon deposit on top of the piston but it was easy to remove with my fingernail (thanks amsoil)
A bit of blow by on the side and exhaust side.
What concern me are the vertical "scratch" marks on the piston, obviously it scraps the wall some and i dunno if it's normal and how much is acceptable. There is 2-3 deeper scratch on top (the black parts) on the 1st pic
I can't take good pic of the cylinder tonight, I'll try tomorrow and post.
you can see a difference in color of the plating where the rings set compare to the rest of the wall on the lower part of the cylinder. It doesn't look like the plating is gone, the color is not aluminum.
What do you all think? Safe to run another season by just replacing the rings?
thanks
