Gear Shift Fault
- jr111
Gear Shift Fault
Hey everyone -
So I decided to do bike maintenance a little early this year. Weather was 60F, sunny and just right for some back yard bike prep. Anyway, after I greased the swing arm bearings, cleaned the chain, oiled the air filter, etc., I cranked it up to go for a spin...except the 220 wouldn't shift into 2nd.
Clutch feels good at the lever, no funky noise going into first, plenty-o-lubrication at the site glass, but no upper gears...even when riding around in first. Appendix 15-3 in service manual says gear shifting fault could be from a number of things. Bike sat out a couple of seasons two years ago...road a few times last year. Shifter returns to normal position easily after attempted shift. Shifter not hitting the case.
Any 'first thoughts' on the issue?
'02 KDX 220
'04 KLR 650
'04 KLR 650
The bike shifted fine when you rode it last?
The shifter is hitting something other than the case.
The number one reason for 'all of a sudden shifting problems' is 'all of a sudden new boots.'
- MXOldtimer
My stock shifter was made a little wrong. I had to run it low to get it to move enough to up shift. If I put it in a normal position it would hit the case just enough not allowing it to go into the next gear, LOOKED/felt like it was moving enough.
Move the lever down a spline or two then ride it and see if it shifts.
04 KX-250 Hey.....at least it's green and smokes.
06 KDX-200 for off road play. Gone but not forgotten
07 KX-250F SOLD! I thump no more.
...except for
Kind'a curious about
As opposed to no upper gears when NOT riding around in first?...but no upper gears...even when riding around in first.
Re: '..little cap screw..'?
What'd I miss?
What'd I miss?
- scheckaet
my vote goes to the kips actuator beeing broken and the gazillion pieces stuck in the gear... I had that happen to me...
take the clutch cover off and look for metallic shavings inside and other obvious damages...
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
OK...which effects shifting how 'zackly?
Uh...when did the subject change to the KIPS from, '..won't shift into 2nd gear..'??
- scheckaet
when it happened to mine, I was pretty much stuck in 1st, symptom beeing similar I thought I'd throw that in the mix...just trying to be helpfull
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Ohhhh...you mean the broken PIN off the actuator shaft is jamming up the gear shift mechanism?
Sheesh...that didn't dawn on me 'til just now.
...that's awful. N8 said as much...I got stuck on the '..open up the little cap screw...' part.
I could'a just read what he said. THAT would'a worked!!
Sorry, folks.
Got it.
Thanks!
Sorry, folks.
Got it.
Thanks!
- jr111
Thanks for all the responses. Yep. Bike was shifting fine last summer...and same old boots.canyncarvr wrote:The bike shifted fine when you rode it last?
I don't think I have a faulty "operator" - me being the operator...laugh. Didn't see any obstructions. Also, I tried upshifting by moving my entire foot up off the peg, too...as opposed to using the peg as a pivot point. That said - will look for any anything else obvious.
MXOT - I'll try dropping the lever a notch or two.
The whole "metal parts in the clutch assembly" doesn't sound good.
Since it's Saturday and the wife will be out for a few hours, I'll take the lads out for some motorcycle mechanics 101. Maybe they will teach me a thing or two!
'02 KDX 220
'04 KLR 650
'04 KLR 650
Do what N8 said.
That will tell you in a few seconds if the KIPS has anything to do with it.
Just 'cuz it wasn't broken last time doesn't mean it can't be broken now.
What's the top-end history? The last one in knew about supporting the KIPS rod while wrenching on it and the LHT part?
