and the spec is 0 to 2mm above the mating surface and it was right at the mating surface. If I turn the fuel off 5-10 seconds before doing downhill, it runs ok. So I thought this proves it is a fuel level issue. I have made 2 adjustments to the level and it is now at 21.5mm and the fuel level is now at least 2mm below the mating surface. It is much better, but still will die if I ride up a small 7-8 foot hill in my back yard and then let it coast back down (it is a 15 degree hill). The only thing that fixes it is turning off the fuel 5-10 seconds before going downhill. I have thought of just buying a new PWK35 (should I get an airstriker, I don't even know what that does), but I hate to spend $230 and it work no better. Is there anything else that could cause this? When I had the carb off checking the fuel level with the gauge pictured above, I tilted the carb 45 degrees forward. After about 10 seconds some fuel started leaking out of the bore where the intake rubber boot would connect. But it was just maybe 1 drip every 4-5 seconds. When I moved the carb back to level, the fuel level was just a bit higher, but not much.
