Cylinder Plug for Powerwashing
N8Strine
Post by N8Strine »
Here is an aluminum plug I made for powerwashing the bike with the exhaust off. It is just a piece of aluminum turned down with two grooves for the orings.
seanstrx276
Post by seanstrx276 »
Looks good! where did you get that piece of aluminum?
Id like to have something like that to seal off the top end when doing a leak down test.
Sean
N8Strine
Post by N8Strine »
Turned it down from a piece of round stock at work on the lathe.
RBD
Post by RBD »
seanstrx276 wrote:Looks good! where did you get that piece of aluminum?
Sean
Sean, go to your local auto parts store and get a "expanding rubber freeze plug". Find one that just fits into the exhaust port, slip it in and tighten the nut, the rubber plug will expand and seal the port.
I use these all the time for pressure testing. You can also get one for the intake spigot to seal it up too.
Ron
