Sticking Throttle
- reymund77
Sticking Throttle
Hi everyone, any idea how to prevent a sticking throttle on the KDX220?.....possible to fix in a twin cable throttle assy just like the XR4?
I've got a phobia on this as my last bike a KTM200EXC broke my femur when I got a sticking throttle at a bend on a single track....next thing I know I was down with a broken femur and crack hip bone...it all happens so fast and sudden that its just a second or two to pull clutch or hit the kill switch but was just caught in surprise
Any hope will be much appreciated.
- scheckaet
be sure:
1 your cable is not frayed
2 the cable housing is not full of dirt, oil... use some carb cleaner to clean it , lube the cable when it's dry
3 your throttle tube is clean and dry, NO grease.
4 put grease on the cable at the bend on the throttle
5 clean carb slide
shouldn't have to worry
my.02 cents
5 clean carb slide
my.02 cents
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Re: Possible to fix..
Meaning a push-pull I suppose.
Sure, it's possible. ..meaning you can reengineer the whole system. Realistically? No.
The KDX throttle isn't known for sticking. It's not something you need to worry about. That said, I don't have the broken leg, huh?
In addition to the above list, DO make sure the cable retainer (white nylon piece) is properly seated at the top of the slide. That won't likely be a problem if you haven't had it apart. If you have, DO make sure the slot in the nylon piece is properly aligned with the cable..and that is sits FLAT on the cable holder (the piece that screws into the top of the slide).
A second option to hitting the kill..and maybe more 'natural'. If your throttle is stuck, the first think you likely think of is stopping. JAM that back brake! That'll stop it.
That doesn't work too good if you're airborne.........
- skipro3
Need another opinion? No? TOO BAD!!! You're gonna get it anyway. I recommend you use a dry lubicant. These are usually a graphite type with an alcohol carrier to distribute the dry lube. Using a dry lube prevents dust from attraction to the cable and it's contact points. BTW, I recommend the disassembly of the carb slide to clean it all properly. Seems every time I take my slide apart, there is a mud-like layer on a part of the slide itself. Could be the throttle sticking is not the cable but instead is the slide sticking in the carb body. Used to happen all the time with the carbs on the KX500's . I think they were the D slides or Flat slides; can't recall but they did stick at just the right harmonic of vibration. Then WATCH OUT!!
Jerry
- kawagumby
Pull in the clutch! Single track you should alway have fingers on the clutch and brake levers. No excuses! place the kill switch where you can easily hit it with your thumb while holding the clutch. (many times I've had the engine scream for 30 seconds or so when the bike flew into brush and pulled the throttle cable taut and still no blown engine). Even if you can't find the kill switch fast enough the worst that will happen is a blown engine. That being said I've never had a throttle stick (without the fore-mentioned provocation) on a KDX - from 86 on up. I too like a clean and dry throttle tube on a sanded smooth handlebar (if it's painted).
Another reason not to own a silly auto-clutch!
And of course, there is NO relation t'wixt the two!! That couldn't be!!!
I don't lubricate my cables. Everytime I've done it, cable failure was right around the corner. I do replace them every couple years..no amount of lubrication is going to prevent a multiple strand cable from wearing the inside of the housing. AND..when you flush all that junk down the tube..you end up with a mud-like layer in places you don't want it.
..No..I don't know of a place you ever WOULD want such a thing. Some folks like it, evidently.......
Banshee throttles are famous for stickage...that's where Yamaha's Throttle Override System (TORS) system came from. If you think a one-cylinder 2-smoke WOT stuck is fun...try two!
- reymund77
- skipro3
I thought I made it clear that the rider is to remove the cable from the carb when cleaning and lubing the cable; hence the reference to disassemble the carb. How can a DRY lube attract dirt to form mud any ways? I've always thought that air was being ingested into the carb from the throttle cable opening and unfiltered air was depositing that dirt. Is there any reason to believe air is NOT being drawn in either through the cable tube itself or the loose fit where the cable meets the carb? Just wondering......canyncarvr wrote:Seems every time I take my slide apart, there is a mud-like layer on a part of the slide itself.
I'm not a know-it-all after all...... ha!!!!
Jerry
- Mr. Wibbens
I guess somebody has to be the odd ball
I use Triflo on my cables whenever they get a lil sticky
Got one of those fancy cable luber thingy's
Works great so far
Works great so far
Isn't that a wonderment?How can a DRY lube attract dirt to form mud any ways?
I have used dry lubricants in the past..and always end up with the same kind'a mess you refer to. When I don't use any (lube)...I don't have any (crud).
If I do something 1/2 dz. times (that everyone does and everyone knows you're supposed to do and who DOESN'T do it anyway?) with always the same result (bad)...I stop doing it.
