Steering Stem, Pressed Down and Out or Up and Out?
- skipro3
On the bottom...The gap between the stem and the clamp... look inbetween... you will see a thick flat C clip in there.KAY DEE EXER wrote:In my gallery theres a photo off the stock KX bottom clamp, where's the clip you mention? ThanksIndawoods wrote:The KX stem has a clip at the bottom to prevent it from being pressed too far in, so this alone gives you an indication of how it is pressed in.
- skipro3
That is on his KDX tree.... You'd have to ask m0rie....
- skipro3
My mistake. I thought that was the KX clamp. Guess I should learn to read his captions or something. I'm going to use the photo and take my lower KX tree with my KDX stem and have a local shop install a pin for me. Just some insureance to the knurling now used to keep the stem snug.
Jerry
- KDXer
Press it out... then you will see what I'm talking about. On second thought... I still have my KX stem... I will take a pic of it today...
