Ride Report
- dave04kdx
Ride Report
I got a chance to put some miles on the KDX yesterday after the new top end, V Force III Cage and the RB Head Mod. HOLY S*&T what a difference.
My bike feels totally different, almost a hint of a 250 in there somewhere. Lofting the front wheel in third is just a twist of the throttle. Lots of low end grunt, better through entire powerband. My 10 year old even told me "Your bike sounds different, better".
- 2001kdx
I think I have too many Azirona Daves cornfused...but:
You're still running the 35mm carby?
**never mind** After reading through six pages of threads with a 'dave' in it, I found:
'My engine is stock except for the RB Carb...'
..but that was 1 1/2 years back.
NOW then...is that on a 10% toluene mix? Or..you don't use that anymore?
Xylene?
You left out too much good stuff!!!
Oh...are you running 'stock' timing?
AND...top-end break-in #1 or #2..and what DO those numbers mean?
The VF3 is great fun, ain't it?? Glad to hear you like yours!!
Xylene?
- dave04kdx
I still use the 10% toluene mix, it works well and I'll never run without it again.
I am running stock timing. Have you changed yours?
I guess I broke my top end in with the old school method. I ran it for (4) 10 minute sessions blipping the throttle. I allowed the engine to cool to ambient temperature in between the 10 minute runs.
The VF3 is great. I made it up a hill yesterday in 3rd gear that pre VF3 required a downshift to second. Granted the top end is new but I could feel something way different in the bike. Oh yea, I also had my head RB'd. Anyway, KDX is running way good!
Re: timing
I've changed mine back and forth a few times. Probably time to go through the process again considering recent changes made to my bike. The last go-round with timing 'spearmints' got me back to 'stock'. I don't need to enhance the bottom (advance) or the top (retard) for any reason. My bike runs fine wherever.
Actually..I don't WANT more bottom end and I sure don't NEED more top. The OEM timing seemed to be about 'in the middle' of things.
Yeah...toluene is something, ain't it?! I love that stuff!! (THANK YOU Ron!!) Guaranteed there are those (most) that will never try it and maybe don't have the bike tuned to the point it would even be of any use..but there are also some that won't get the ride they could have if they don't have a 'full disclosure' ride report!
Good to hear!! Thanks for the post!
Where do you run your air screw btw?
- dave04kdx
I'm still experimenting with my air screw. The weather has been all over the place this winter. 1 week of highs in the 40's and cloudy to 80 degrees and sunny the next week. Around 2 5/8 seems to work well on warmer days. Around 2 1/2 is good on cold days. We are heading to see my Mother-In-Law this weekend. Elevation is 3500 to 6500 ft in area that I ride at her house. It will be interesting to play with a/s there without messing with jetting and see how it works. BTW elevation here is 1300 ft.
- dave04kdx
Hey RickAZRickD wrote:I have all of those mods, but I always wonder what my modded, and now 4-year old '03 would feel like if I put in, say, new rings, or new rings and a piston. It has the Wiseco from two years ago... just wonderin'.
Rick
A new top end in any of my 2 strokes always made a difference if the engine has a lot of time on it. It seems to me the "crispness" of a new top end doesn't last more than 50 hours or so. Maybe my imaginaton?
I'm curious about the SSS setting in this light:
Considering it has such an impact on 3rd gear pull (for example), I'm convinced the modified carb 'lo-speed' circuit adjustment has as much to do with fuel as it does air. I've experimented specifically with this only a couple of times..but there have been rides when temp changes significant enough to matter to air screw adjustment have turned out to be 'farther out' ran better when the temps dropped and 'farther in' ran better when temps rose.
Again, the range of that adjustment has consistently been less than 1/8th turn, but the effect is huge!
Your ride this weekend at significantly higher el. would be a good place to try that out.
Re: 'It seems to me the "crispness" of a new top end doesn't last more than 50 hours or so. Maybe my imaginaton?'
Time to try break-in #2.
Have a good ride!!
Have a good ride!!
- dave04kdx
Rons carb mod is awesome. Its nice to have something actually work and in this case work better than advertized. My bike is jetted for around 1500 ft, around 70 degrees F. My son and I went riding Saturday around 3500 to 4000 ft. It was much cooler, around 55 or so. The KDX was blubbering a bit so I gave the A/S a bit more than an 1/8 turn out. She ran like a champ all day. I love the difference with the V Force III, head mod. The bike pulls like a tractor. Seems like I'm going on and on but I can't get over the difference from stock.
luke347
The only way I could see getting a HOLY S&#* difference was if some one was very mean and plopped a kx 250 engine in my kdx, and yes I have rode 250 mxers and to me thats a pretty big difference have you guys ridden 250 mxers just wondering on the scale from kdx to kx 250 where do all these mods put you? if its half way and your still wanting more power why not try to dull down the 250 mxer or a orange 250? or just ride a stock ktm or gas gas 200 reading all these good things about the mods make me wonder 2 things if it is like a ktm 200 why not get one 2nd thing is with all these mods to make it more like a ktm 200 isnt it gonna end up costing the same as the 200 with all your mods and kx front conversions and re valving? but maybe its still calmer than a ktm 200 but as much or little less power?
Just trying to find these things out, because i think im gonna go orange soon maybe a 200 who knows I dont really have the money for one right now though and dont see my self doing these mods to my own bike.
- quailchaser
Having gone from the KDX220 to a KX250, I have to say it's a mixed bag.
They are different animals even modding the MX bike to Woods configuration. The KDX works fantastic for what it was designed for...tight woods type riding. Yes, my KX will handle that stuff...at a cost. You must be committed to the power. There is little forgiveness compared to the KDX. Modding the KDX mearly improves it's overall potential, but does not take away from it's designed purpose...great woods bike. It'll take to being ridden hard, and still shine when ridden easy. I haven't been on any MX bike that does this anywhere near as well as the KDX. There are things that my KX will do that the KDX will never do and vice versa. It's a trade off. The DRZ is a great dual sport bike...can you dual sport a KDX? Certainly. Will it be as good at this as a purpose built dual sport like a DRZ? No.
It's like the tire debate. There is no tire that does it all great. There is no bike that does it all great either. Same thing with the KTM200. It's a great bike...but it's not a trail bike. It's a race bike. Can you make it more tame? Yes. Will it still work it's best wrung out? Yes. Will it still cost a brazillion dollars? Yes. I haven't met one KTM200 rider that hasn't modded thier bike. Still have to do suspension. Still have to fit the bike to your likes. Except that they are typically $2000++ more expensive than a KDX. And I repeat, you still will have to mod it.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
- krazyinski
good to last point, If I had an opinion on this subject it wood be as said by qc.
luke: I've tried reading your post 4-5 times...only to end up every time with my eyes dancing in their sockets looking for phrasing, meaning...and some punctuation. It's like (I guess) a PSE attack from looking at a 7FPS strobe.
I get the sense from QC's response that you are comparing a KDX to a track bike?
If you are stuck with what you buy ('..don't see myself doing mods...), you are indeed stuck in any case.
Have fun riding a KX250 with 10-24s in the base valve in the woods!! You are going to get beat to death!!
Have fun flying a KDX220 over a 70' triple. You are going to die.
Just pick a color you like...go riding and have fun!
How's that?
We'll wait for 'ya!
How's that?
We'll wait for 'ya!
- KDXer
RE: Have fun flying a KDX220 over a 70' triple. You are going to die.
Not a triple but tabletops I've done better than that by 5 foot with STOCK KDX forks. I wouldn't advise it but it is possible. Now with KX forks I've hit 85+ foot. There is a 100 footer I am yet to attempt.
GS
luke347
Yea but even though the ktm 200 is 2000 dollars more how much are you guys ending up spending with your carb, head, forks, revalving and reed cages I bet if you guys put it up against the price of the ktm 200 you guys are spending maybe $500 less? Plus I know some of you guys are racing your kdx's with all these mods why dont you just get the ktm 200? If my racing become more competitive within the next two years I'll be riding the 200 or 250 xcf with some hand guards and a skid plate. From what I hear these days thats all you need with the new ktms even with just minor suspension changes.
A stock KDX with $700 worth of mods is all you need.
$1300 can get you a support vehicle.....
- 2001kdx
