I did pose the "how to disassemble" question on SN to see what is brought up there. I did a search and found reference to the possibility of knock off CVs that are VERY cheap for replacement purposes if need be (OEM = $200 per bikebandit), 'need to find out more.
Yes, I tried to remove with just heat - no go, and given the suspected pins/stakes I'm resisting overdoing it. I treated the heat gun with respect, but I did manage to lacerate the webbing between my thumb and index finger on my left hand so I do have one bandage!
So, whilst I wait - the good stuff. The shim stack that fell out of the partially disassembled CV goes like this (all are 0.10mm thick, 8mm ID): (4) 27mm, (1) 12mm - huh?, (1) 20mm, (1) 18mm, (1) 16mm, (1) 14mm, (3) 11mm. Washer that came out after the nut is 20mm OD, 8mm ID and almost 2mm thick.
If I eventually change this config, I think I can do the same for the CV that I haven't mutilated without needing to tear it apart. If I can manage to secure the rod with it pushed all the way down (so the rod doesn't move up and out of the midvalve), the nut, washer, and shims should fall out. Then when I reassemble I just need to be creative in getting them back on the rod end.
