well I found my wrench, but i can't find my book. can someone give me the torque settings for:
the linkage bolts
swing arm
shock
thanks
my favorite quote about torque, not sure about the source:
"speed is how fast your going when you hit the wall. torque is how far the wall moves when you hit it"
Torque settings
- layoutd
- stringburner
marco220
Tighten until you feel it strip and then back off a quarter turn!!!
If you insist on using the correct torque settings.....
Rocker Arm Nut: 65 ft/lb
Shock Bolt: 29 ft/lb
Tie-Rod Nut: 61 ft/lb
Swingarm Pivot Bolt: 65 ft/lb
Sorry for the duplicate of the same info -- for some reason I didn't see the first reponse when I submitted.
2002 KDX 220
RB'd Carb and Head
I don't crash often... but when I do, I'm going for style points!
RB'd Carb and Head
- stringburner
