How do you pack extra fuel?
My last bike was a KX500 with a massive desert tank. I've looked into the Clarke desert tank for the KDX but it doesn't seem a large enough increase to justify the price. How do you guys pack extra fuel for the long rides? Most trips I don't need extra fuel, but every once in a while I will.
- KDXohio
Re: How do you pack extra fuel?
Couple of 30oz MSR backpacking fuel cans in a backpack.
- KDXohio
Wow. Those are awesome. I didn't know those existed. I've filled up old anti-freeze cans and strapped them to my front number plate before but I can't do that on the KDX because of the headlight. I may be able to find a way to slip those behind the headlight. Cool.
- KDXohio
You could get an oversized fender bag and put them in there with a couple caribeaners you may be able to clip them to the handlebars then wedge them behind the headlight and the gas wont eat through these like plastic bottles!
I have a knock off KLX look-a-like headlight. It has a little more room behind the headlight than the stock headlight. I'm wondering if I could modify a couple of cup holders or make a bracket that mount to the triple clamp.
I had a 5l fuel can hooked up to a custom rack on the rear fender, but it made technical riding way too hard, so I now just use two 1.5l coke bottles strapped in another rack. Probably wouldn't be legal in the states though, lol. Those MSR bottles are good. Quite sturdy too.
- kx200
The next best thing is a Lectron carb. Last race was two 45 min GP style races. I checked to see how much fuel was left after a race. This time after both motos I had a 1 gallon.
Acerbis make a fuel cell that mounts to the handlebar ( cross bar ) they also make one that mounts to the rear fender too .
- IDRIDR
Wolfman enduro saddlebags and two primus 1.5l fuel bottles.
2003 KDX 220. RB Carb & Head Mods. Desert pipe. She's a runner!
2006 KLX 250 w/351 big bore. A well-sorted dual sporter.
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
2014 Suzuki DL1000.
I have used a can of trufuel before. You can use the gas that's in it or refill with your own.
http://www.lowes.com/pd_50786-442-65255 ... facetInfo=
