Quick needle question
NM_KDX200
Post by NM_KDX200 »
When we're talking about DEK and CEK needles, is that all there is to the number? I can call Sudco up and say "I need a DEK needle" and get the right thing? I'm just trying to figure out why there's an 1174 and then DEK- doesn't make sense. Why not 1254 or something like that?
Thanks,
1999 KDX 200
2001 KDX 220
2002 RM 134
2004 KX 125
skipro3
Post by skipro3 »
The 1174 # is a Kawasaki part #. The DEK or CEK is a standard part #. Order both and a bunch of jets, main and pilot. The shipping won't increase and there is usually a $25 minimum parts order anyway.
Jerry
IdahoCharley
Post by IdahoCharley »
Sudco part number for CEK N427-48-017-430 for DEK N427-48-017-508
The first nine numbers are the same the last three digits denote the specific needle.
Check out the Sudco online catalog page 116 for specific needles numbers. That said - if you tell the sudco person your looking for needles which are N427-48-017 CEK and DEK they should have no problems.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
Green Hornet
Post by Green Hornet »
What is a 1173/74 comparable too? CEM, DEK ??
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
m0rie
Post by m0rie »
Green Hornet wrote:What is a 1173/74 comparable too? CEM, DEK ??
The 1173/74 needles are a B series needle. BEP if I remember right would be the Keihan crossover.
1989 KDX 200
2007 TTR-50E
Has thanked: 153 times
Been thanked: 38 times
I think they are BGP and BGQ.
m0rie
Post by m0rie »
Jason wrote:I think they are BGP and BGQ.
Thanks Jason - I thought it was something like that.
1989 KDX 200
2007 TTR-50E
"Me thinking" does not make it so. :lol: I just remember the stock 1989 - 1994 KDX200 needle as "biggun", like "Hey, Big One". :lol:
skipro3
Post by skipro3 »
If you look at the info from Canadian Dave's site, it shows that the 1174 translates to a needle that isn't manufactured by sudco. Or anyone but Kawasaki for that matter. It's been a while, but that is what I recall. That is a good read though. I printed it and review it occasionally.
Jerry
KDXSean
Post by KDXSean »
I know most of you folks in the U.S. run 200's, but will the CEK and DEK work for a 220?
I am still currently using the standard carb (re-jetted), and a torque pipe. Set up works good, but I want to fiddle with some different needles now.
Also, will the CEK and DEK needles work with the stock slide?
ski, I don't know who makes them, but sudco has a 017-070, which is a BGQ (AKA R1174N).
Green Hornet
KDXSean wrote:I know most of you folks in the U.S. run 200's, but will the CEK and DEK work for a 220?
It will be too rich a needle for the stock slide#5, obtain a #7 ($60)-Sudco or send the Carb to RB for the Mod.
I tried and it's too RICH
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Colorado Mike
Post by Colorado Mike »
KDXSean, my 220 is running with a CEK. My carb has the RB mods on it though. the needle will still fit yours, but I don't know how well it'll run.
Mike
'04 KDX220
Green Hornet, which needle(s) did you try on the 220R? My friend wsjkawasaki is adjusting his jetting on his 1997 KDX220R, so any help on which needles will/won't work would be great for him.
Thanks!
skipro3
Post by skipro3 »
Colorado Mike wrote:KDXSean, my 220 is running with a CEK. My carb has the RB mods on it though. the needle will still fit yours, but I don't know how well it'll run.
Ditto
****EDIT****
NOt Ditto. I have the AirStriker carb, not a modded stock carb. Sorry
Jerry
Green Hornet
I'm running the 1173 needle in the 35mm. Tried the CEK was Four Stroking BIG TIME.
The xEM needles work well with the stock #5 slide (generally). I'd either get a #7 slide or a CEM needle and try from there. I'm saving the CEK needle for when I have the RB mod done.
The 1173 needle is a bit richer then the 1174. Fredette recommended the 1173 in the 220/35mm Setup
Ron does modify the SLIDE to LEAN it. That is why the CEK will work well in it. Or you can buy a #7 slide.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Thanks for the info. He has the 33mm stock carb, and I was thinking you had the 33mm stock carb, too. Sorry about that.
Green Hornet
FYI-If anyone picks up a 35mm carb that is pre 95, DO NOT SEND TO RB for the MOD. Ron wrote to me that the material that Keihin used then is different then the 95 - current and he CAN NOT do the mod. Heres what he wrote:
In the past several months I have had a few people send me 35 mm PWK's that they bought from e-bay and none of them have been any good. Most of them have been pre 1995's and have the non plated slide in them. Also the chokes and float needle and seat are shot along with the special o-ring gasket seal for the jet block.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
m0rie
Post by m0rie »
Green Hornet wrote:FYI-If anyone picks up a 35mm carb that is pre 95, DO NOT SEND TO RB for the MOD. Ron told me the material that Keihin used then is different then the 95 - current and he CAN NOT do the mod. Heres what he wrote:
This would be a recent change on Ron's part. He has done several pre-95 carbs in the past. One of the changes for them was to bring the jet block upto the same height as the 95+ carbs (pre 95 carbs have a 2mm lower jet block) as well as the rest of the rb mods.
I'd imagine that he is warning against using the older carbs simply from the stand point of being worn out.
-Maurice
1989 KDX 200
2007 TTR-50E
TD3
Post by TD3 »
How does this affect the jetting of the pre 95 carbs? Are most of the recommended setups based on the post 95 carbs?
What does he do to make it leaner?
My KDX is proving to be a PITA to jet so I'm considering a newer RB modded carb in the future.
