pipe ... (sigh)
- Mr. Wibbens
- KDX Butterfly
- Queen B
- Mr. Wibbens
Is that a stock pipe?
I'd get new packing
Is it steel wool? Might be able to clean it by soaking it in solvent
I'm pretty sure steel wool will burn, so definitely don't use a torch on it
I'd get new packing
- Mr. Wibbens
>|QBB<[/url]
You are lucky you don't have an fmf
that really looks pretty goodKDX Butterfly wrote:can i clean the packing or do i need to get new?
- dan46n2
Maybe because it was pink and I felt emasculated by it, I dunno...Mr. Wibbens wrote:>|
Seriously?
Why is that?
I've been using Silent Sport (its not pink) for about 7 years. One bag will last at least 3 - 4 packings. It is super easy to use
I think it came down to the design of the silencer (for me)- With the sleeve off, I had to try to wrap as much pink frilly stuff around the perforated inner pipe. I wrapped as much as I could and it was just a bit tricky to try to keep it all wrapped fairly tight and slide the sleeve over it. I feel that having a sheet/roll that I could cut to the right length (matching the inner perforated pipe) would have been easier and I likely could have put more packing in with it more evenly distributed....
YMMV, this was just my first experience with repacking a silencer.
- Has thanked: 5 times
- Been thanked: 10 times
Yep, that is a stock E series silencer. That looks like factory packing as well and it needs to be replaced.
Pick up some of the rolled type 2T silencer packing (I use FMF and get 3 repacks out of it), cut it to the same width as the factory one, then wrap it around the pipe, and tape it in place with masking tape. Then reassemble the pipe and you are done!
- KDX Butterfly
- Queen B
- Mr. Wibbens
I pack mine fairly loosely
You want it to fluff up
Does not really pertain to this thread since it looks like Budderfry has a stock pipe
But I connect the stinger to the turbin core as pictured
Then I pull some handfulls of string out of the bag and pull it apart with my fingers, then evenly as possible start stuffing it around the core
Then slide the assembly down further and add more, and more
Put some hi-temp sillycone on all the joints and hardware and you are done
Yep, that will work fine.KDX Butterfly wrote:locally, i can get moose and it is 7.95/per packing
Uh, I sure wouldn't!KarlP wrote:can i clean the packing or do i need to get new?
Sure, put the whole thing in your dishwasher.
It'll work out great!
- KDX Butterfly
- Queen B
- KDX Butterfly
- Queen B
- KDX Butterfly
- Queen B
- KDX Butterfly
- Queen B
- Mr. Wibbens
masking tape
- KDX Butterfly
- Queen B
- KDX Butterfly
- Queen B
