e series pegs....
e series pegs....
Hmm. I just found out by accident that after just a couple whacks with a hammer to narrow the mount, 93 yz250 pegs fit perfectly on the E series KDX. Dunno if this info will help anyone else. Free pegs for me though, much wider than the stock pegs. I like it!
http://cgi.ebay.com/ebaymotors/Yamaha-Y ... ccessories
The pegs in question ^
On my bike ^
Interesting. It looks from the pic to sit higher than the stock peg. Is that in fact the case? If so, how much?
Yeah, about 1/2". Just fine for me, being 5'6". It might be enough to bother a tall fella, but I doubt it.
Bummer. I already have a hard enough time finding my rear brake with the stock pegs. I would think another 1/2" would drive me nuts trying to find it, however, I still might give them a shot.
Edit: After looking around a bit, the pegs you have appear to sit a lot higher than stock YZ pegs. I definately will try a set and see what I think of them. BTW, here is a link to some pegs that look like the IMS pegs but at a reasonable price: http://www.d2moto.com/p-4968-90-05-yama ... -pegs.aspx
Those look sweet, and lower than mine. For that price I will have to try a set. They LOOK stronger than these pegs, anyway.
The ones I have are definitely stock for a 93 yz250. From what I can find, the same pegs are used on yz250 from 92 - 96.
Also the following bikes, according to cheapcycleparts nifty parts cross-reference...
* » Yamaha TT-R125E (TTR125LES) 2004
* » Yamaha TT-R250 (TTR250T) 2005
* » Yamaha TT-R250 (TTR250V) 2006
* » Yamaha TTR125 (TTR125M) 2000
* » Yamaha TTR125 (TTR125MC) 2000
* » Yamaha TTR125 (TTR125N) 2001
* » Yamaha TTR125 (TTR125P) 2002
* » Yamaha TTR125 (TTR125R) 2003
* » Yamaha TTR125 TTR125LS TTR125L (TTR125LS) 2004
* » Yamaha TTR125 TTR125LS TTR125L (TTR125S) 2004
* » Yamaha TTR125ETTR125LER TTR125LE (TTR125ER) 2003
* » Yamaha TTR125ETTR125LES TTR125LE (TTR125ES) 2004
* » Yamaha TTR125L (TTR125LN) 2001
* » Yamaha TTR125L (TTR125LPC) 2002
* » Yamaha TTR125L (TTR125LR) 2003
* » Yamaha TTR125L (TTR125LWM) 2000
* » Yamaha TTR125LE (TTR125LER) 2003
* » Yamaha TTR225 (TTR250RC) 2003
* » Yamaha TTR250 (TTR250M) 2000
* » Yamaha TTR250 (TTR250MC) 2000
* » Yamaha TTR250 (TTR250N) 2001
* » Yamaha TTR250 (TTR250NC) 2001
* » Yamaha TTR250 (TTR250P) 2002
* » Yamaha TTR250 (TTR250PC) 2002
* » Yamaha TTR250 (TTR250R) 2003
* » Yamaha TTR250 (TTR250S) 2004
* » Yamaha TTR250 (TTR250SC) 2004
* » Yamaha TTR250 (TTR250TC) 2005
* » Yamaha TTR250 (TTR250VC) 2006
* » Yamaha TTR250R (TT250RL) 1999
* » Yamaha TTR250R (TT250RLC) 1999
* » Yamaha WR250ZD 1992
* » Yamaha WR250ZE 1993
* » Yamaha WR250ZF 1994
* » Yamaha WR250ZG 1995
* » Yamaha WR250ZH 1996
* » Yamaha WR250ZJ 1997
* » Yamaha YZ125 (YZ125G1) 1995
* » Yamaha YZ125D1 1992
* » Yamaha YZ125E 1993
* » Yamaha YZ125F1 1994
* » Yamaha YZ125H1 1996
* » Yamaha YZ250D1 1992
* » Yamaha YZ250E 1993
* » Yamaha YZ250E1 1993
* » Yamaha YZ250F1 1994
* » Yamaha YZ250G1 1995
* » Yamaha YZ250H1 1996
* » Yamaha YZ80 (YZ80M1) 2000
* » Yamaha YZ80 (YZ80N1) 2001
* » Yamaha YZ80K1 1998
* » Yamaha YZ80L 1999
You might have to drill a hole for the spring on the RH side, the LH had the hole in the right place.
Hmm, TTR125 pegs. I have one those around so I can check it out.
80elkster
Post by 80elkster »
SS
Did you try to test fit the TTR125 pegs on your E series KDX. I was kicking around the idea of buying some pegs for mine
06 DR650 Farkled
91 WR250 2T
00 300EXC (Sold)
79 XS850 (Sold)
79 CR250 (Sold)
78 IT400 (Stolen)
75 G5 100 Kawi (Gave it away)
73 F7 175 Kawi (Sold)
70 175 Brigestone (Recycled)
05 KDX200(Son's)
93 KDX200
75 KT250 Trials
250 Quads
Just glad to be ridin!
If they're in that list, they should fit.
80elkster wrote:SS
Wow, somehow I missed this. Sorry!
No, I didn't try them and unfortunately I cannot now as someone stole the TTR this past Wednesday.
Damn, that sucks!
Yeah, the bastards got away clean. No news from the police on it so far. (What a surprise :roll: )
Looking at doing this finally with my build and had a question. Juliend, did you use the YZ spring or the stock KDX spring with the YZ pegs?
I THINK i used the kdx spring. I am not 100% sure on that.
Just got my set of Ebay special pegs for my build. Thought I would post up in this thread about them since this is where we originally discussed these pegs.
The pegs are listed for "90-05 Yamaha YZ 80 125 250 500 WR 200 500 Honda XR 350 500". The mounting hole is an exact match to the stock E series peg pin. Unfortunately, they are pretty wide at the mounting point so a little bit of grinding was in order. There is still plenty of thickness so I feel OK with thinning it a bit. The only thing special you have to do with the springs is to swap them from left-to-right and right-to-left. Absolutely no modifications are needed for the stock springs..
I ground the side of the mount that faces towards the ground.
I also had to grind the inner lower mount (red arrow) to get the peg height just right. I spent about 30-35 minutes on one peg using a Dremel. I took my time as I didn't want to remove too much material.
So, a little bit of time, a Dremel, and some $18 Ebay pegs, and I got a peg that is a lot more comfortable to stand on, grips better than stock, and didn't hurt my wallet. If they hold up then these are a bargain IMO.
kkim
Post by kkim »
I bought a set of pegs from d2moto made for the kdx. why are you buying pegs for another make/model instead and having to modify them to fit? what am I missing here?
http://www.d2moto.com/p-4967-1991-2003- ... -pegs.aspx
Nobody makes aftermarket pegs for an E series KDX unless you want to fork over $75+. The pegs you linked will fit 95 - 2006, not 91 - 03.
Nice work SS. Mine were a touch wide too. I narrowed the mount with a 2lb hammer.
KDX Butterfly
Queen B
Queen B
Post by KDX Butterfly »
SS109 wrote:... unfortunately I cannot now as someone stole the TTR this past Wednesday.
Wow. People suck (No, Not all of them!). My father-in-law always told the boys when they were growing up, "If you're gonna steal something, at least make it worth the arrest." What a philosophy.
"If I were just two inches taller, I wouldn't be me." ~KDX Butterfly
juliend wrote:Nobody makes aftermarket pegs for an E series KDX unless you want to fork over $75+. The pegs you linked will fit 95 - 2006, not 91 - 03.
These wouldn't bend at all so I resorted to grinding on them. They work smooth and I love how the feel on the feet.
KDX Butterfly wrote:>|<>QBB<
Yeah, people sometimes suck. Still haven't heard anything from the police about it. :?
kkim
Post by kkim »
ah, sorry. I thought there was something odd about their application listing. didn't realize the pegs for the E vs H were different.
2017 Husqvarna FE250
80elkster
Post by 80elkster »
I just put a set of these pegs on my 93 and had to grind/file the sides to make them fit then touched up the bare metal with paint.
These pegs are defiinitly better than stock.
06 DR650 Farkled
91 WR250 2T
00 300EXC (Sold)
79 XS850 (Sold)
79 CR250 (Sold)
78 IT400 (Stolen)
05 KDX200(Son's)
93 KDX200
75 KT250 Trials
250 Quads
