funk it. pre-mixjuliend wrote:Mmm. Yes, easy enough to turn the pump up. I said that. Not so easy to know if you've turned it up enough to get adequate oil to the main bearings. You could have it cranked to max and it still not be enough to cover the much larger intake system you are using. I guess when you spin a bearing, you'll know you didn't have the pump turned high enough?moto_psycho wrote:juliend wrote:
Mmmhmm. And how to you figure on reconfiguring that pump accurately for the higher quantity of fuel and air? I know the pump on my old 71 has an adjuster, but I don't have any idea how you'd go about figuring how much more it needs to pump. Seems safer to go with premix. Maybe someone more familiar with the SR will know.
cheeky this post got away from me, if you take the side of the pump off there are marks for calibration, easy enough to just jack it up a bit, but i am still preferenced to running pre-mix, less **** to go wrong!
Do it!
The SR model curse...
I will go for pre mix...i have seem friends pump that fail to work but not to the knowledage of the rider and sized up the whole engine in the middle of trail. you will never know when the 2t pump is going to fail you. no tell tale sign on it.
BTW have you done the USD fork conversion? should go for it if you are serious about riding the kdx.
A true KDX customizer!!
Years ago I had a Kawy 350 F5 (?)
It was a single cylinder dual sport, 2-stroke, with the carb down in the RH side cover forward of the clutch. It used a rotary valve intake. Pretty nice bike.
It had an oil pump and tank and dual throttle cables.
I switched to premix for some reason. I don't recall why. On the advise of a buddy I disconnected the oil pump cable but left the pump and tank intact. The pump continued to deliver oil at the "idle" setting. I think I mixed 40:1.
My buddies theory was that the pump delivered oil to the mains and the gas/oil mix lubed the rest.
I flogged that bike for several hard years before I ran it into a parked car and broke my leg ( )
'08 KTM200xc
KX100 for the boy
KX100 for the boy
There are some varying designs on the oil injected bikes. One variation was to have the main bearings sealed off from the crankcase on the inside, oil was then delivered to the main bearings by the pump through a small orifice. If you removed or disabled the pump on these models, the pre-mix had no way of getting to the main bearings to lubricate them. To get around this, you had to modify inside the crankcase to allow premix to contact the main bearings, else risk main bearings seizure.
yeah but the kdx the oil is injected into the inlet stub before the reeds, so there is no way of keeping the oil pump intact as you have to replace the inlet stub, only other way of keeping it on (basically to avoid making a plate up) would be to take the feed and put it back into the resevoir :p bit pointless but i suppose a worthwhile temporary measure
