Tranny oil?
- Grayhorse
Tranny oil?
Just curious what do you guys run in the gear box? I was using automotive valvoline 10-30 but since I'm in the middle of replacing leaky crank seals I thought I might change it up.
96 KDX 200 H2
- Mr. Wibbens
- Rick
I run 10w-40 in my kdx and cr. Works great. Change it after every other ride, or one really long ride. Its cheap, and easy to do. My ridin' buddy Jim (Jeb) runs half oil, half atf. Both work great.
Yes, they really do let me drive the Train!
1991 KDX 250 $Sold but not forgotten....
1996 Suzuki DR 350 $Sold!
2002 Honda CR 250 worth more than my house at this point........ :-)
2004 DR 650se Road Warrior
2002 DL1000 V-STROM
2002 DL1000 V-STROM
- Mr. Wibbens
I'm currenly running 5w-30 Lucas
Change maybe 2 times a season
- skipro3
I'm using some kind of official high dollar gear lube from the bike shop.
(Recommended for 2 stroke MOTORCYCLES with WET CLUTCHES)
I change it maybe two or three times a year. No big deal.
I sure don't change it very often, but that is just me and my bike, not a recommendation.
I'll reserve comment on the use of Automatic Transmission Fluid except to say I don't have an Automatic Transmission and neither do my FORKS.
(just trying to cause trouble. You all leave it alone)
'08 KTM200xc
KX100 for the boy
KX100 for the boy
Nope, can't leave that one alone. If you just take a few minutes to think about the components which make up an automatic transmission, and the components that make up your bikes gearbox, you will find they are quite similar despite the fact that your bike does not shift for you.
Automatic transmisison - constant mesh gears and a series of wet clutches
Motorcycle gearbox - constant mesh gears and A wet clutch
Neat, huh? What's even better for me is results. Type F just plain works well. Smooth shifts, and tranny bits are always perfect when I tear down.
- Mr. Wibbens
I've tried atf a couple times, I don't care for it, my bike shifts worse using it
Oil seems to work better for me
I can't see changing it as often as some peeps do. Hell it's only used for the tranny.
- Mr. Wibbens
I need to run something light, like 5-30 or the clutch will drag something awful when it is cold
Tranny oil?
Sorry to dredge up an old thread. I am a newbie to dirt bikes, but been riding and wrenching on all kinds of street bikes for 10+ years. Simple question: why do people seem to change the tranny oil so often on dirt bikes? On street bikes with wet clutches, including track bikes, its not common to change the tranny oil every other ride.
I realize with dirt bikes the clutch may see more use, but something so unique about dirt bike transmissions that they warrant frequent changes? I was thinking something like once every 1500 miles or so, if riding dual sport routes (what I would be doing). Am I crazy?
Tranny oil?
I don't have a ton of time on a street bike, but from the riding that I have done, the clutch was pretty much used just to change gears and take off from a stop.xxaarraa wrote:Sorry to dredge up an old thread. I am a newbie to dirt bikes, but been riding and wrenching on all kinds of street bikes for 10+ years. Simple question: why do people seem to change the tranny oil so often on dirt bikes? On street bikes with wet clutches, including track bikes, its not common to change the tranny oil every other ride.
On my dirt bike the clutch is used much more frequently and feathered heavily when I ride in tight conditions which puts a lot of wear on the clutch.
Not to mention that since the dirt bike holds less than a quart, it costs me under $5 to refill the oil.
Saying that though, I don't change it every other ride. I do it after 4-5 rides which is about once a month or longer (unfortunately).
Tranny oil?
Thanks for your thoughts. That makes sense. I have this crazy idea of outfitting and regearing the little KDX to do a 1000-1200 mile trip next year. In addition to figuring out how to strap on fuel cells for all the gas needed between stops and many other challenges, I am wondering how in the world I am going to do a tranny oil change in the middle of a trip like that. Hence my question.Thrahl wrote: I don't have a ton of time on a street bike, but from the riding that I have done, the clutch was pretty much used just to change gears and take off from a stop.
Tranny oil?
My street bike has a oil cooler and a easily changed filter. kdx doesn't and I try not to ride the street bike in deep water or mud.
1997 220, KLX forks-pipe-reeds-trials tire
Re: Tranny oil?
xxaarraa, if you are street riding, you won't need to worry about it. Please be aware of hitting bumps causes the oil to get splashed up on the gears and such. Long road running won't allow this. There was a Kawasaki service bulletin about it.
