Re: 'Juliend instructs me to have multiple unrelated questions in the same thread. You want me to use separate threads. When I went to separate threads before, Juliend was not happy. So, I am happy either way. Let's arrive at one consensus going forward please.... '
Yeah...he did.
I dunno...ask Juliend!
Forty different question in one thread you can see gets stuff mixed up. But then...forty different threads probably wouldn't go over real well either.
Let me think about it for maybe 15 years..and I'll get back to you on it.
I did miss the part about the loose shifter. Good job Karl!
Re: 'You did not ask about mix ratios? The BEST transmission oil?'
I happen to know all about that...but just 'cuz I read it somewhere recently..but can't quite recall where that was...... Gimme a good 15 years to sort that one out, too.
Wait Wait...I remember!
I run the 'BEST' of all-a those, pre-mix/ratio/AND trans oil.
Man. I'm
good.
That didn't even take TWO years!!!
There's hope for me yet..regardless of what <some> say! I kin see the light at the end of the tunnel...........probably a locomotive heading my way.
And..Yessirree Bob on the tape. The amount of movement in the tang is the same as the thickness of the tang (and whatever offset there is in the actual tang angle..usually a little bit to help it 'grab' edges on outside measurements...which can in fact be made INside!
Holy Spooge Batman indeed!!!
