Kdx 220 Stall
Byte
Kdx 220 Stall
Post by Byte »
Riding on my track in my back yard and experienced stalling.
Any thoughts why this may be happening?
Yes, fuel is in tank with petcock in 'ON' postion.
Byte
KarlP
Post by KarlP »
Loose spark plug cap?
Pinched gas tank vent hose?
Trash in gas tank?
Could be all kinds of things.....
'08 KTM200xc
KX100 for the boy
Jeb
Post by Jeb »
How slow are you going when it stalls? I only ask this because this is happening in your backyard.
Are you at low RPMs when it happens? High RPMs? While you're crossing the curb on your patio?
Does the bike die or just stall and light back up? If it dies does it start right back up?
"No farmer ever plowed a field by turning it over in his mind" -George E. Woodbury
CLICK FOR PICS!
Varmint
Post by Varmint »
Fouling plugs? Jet that pig! (TM - Trade Mark, Indawoods)
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
Byte
Post by Byte »
THnaks boys.
Slow RPM up an incline.
I am riding on 5 acres of land with a ready made bike track in place - amongst trees, mud and dirt.
I will check all above this weekend.
Thoughts?
Byte
You're on a 2t, remember? Slow rpm up an incline and you probably need to be feathering the clutch a bit to get that "slow rpm" up a bit. Of course, I haven't got much of a description, but I'm guessing you're just bogging it out.
Byte
Post by Byte »
Thanks Juliend.
No problem Byte. Keep in mind, that is an uneducated guess. I'm not sure exactly what's going on without seeing it myself. I'm sure glad you were riding that thing anywhere though!! Congrats on keepin' on with it!
Riding in too high a gear for the incline possibly?
Byte
Post by Byte »
thanks juliend.
i know it's old technology but I feel comfortable riding it for a play and getting used to riding...
I will pull my 09 300 ktm out shortly and test it out
:rolleyes:
SS109 - Good thought.
Byte
fuzzy
Post by fuzzy »
Nothing old about the technology.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
Mr. Wibbens
Post by Mr. Wibbens »
See that thing on the right side of your handlebar?
Twist it! :wink:
LMAO WIBBENS!
And then, take that punkin back to the punkin patch. I think the KDX is getting offended at having to share space with a big orange yuppie bike :butthead:
J.
fuzzy
Post by fuzzy »
The 09 KTM300 has basically the exact same carburator on it (same since 88 on the KDX)...Learn how to tune it/them.
Byte
Post by Byte »
THasnk boys.
I love the KDX. It feels like a jaguar - with the plush feeling and planted feel on the ground.
I agree - the KTM can be seen as 'yuppie' bike.
Time for a ride :-)
Byte
Just pokin fun man. I've loved every KTM I've ever ridden, except for the super harsh suspension. I'm sure that could be remedied easily enough, were it MY bike to tweak on. I look to have a 200 or 300 xc at some point in time, should my limited budget ever allow.
Byte
Post by Byte »
No worries Juliened - :partyman:
I still have issues with my kdx220.
When I rode it yesterday, I wanted to twist that throttle but simply poofs out and dies - even in first gear on level ground. I do not know how to diagnose this problem.
Spark plug cap is tight.
Gas tank vent hose is not pinched.
Emptied and cleaned gas tank 2 weeks ago.
I admit I travel in between 1st and 2nd gear atm because track is not big enough to go faster. The bike stalls and dies - then have lots of trouble kick starting it again.
The attached photo shows my throttle cable (apologies for picture quality).
The copper bent tube on top of the cap easily turns around and I do not know if this should be happening.
Also, I am not sure if the domed shaped steel sheath for cable should be more tightly snugged up to that copper tube.
The photo shows the cable slightly pulled away from the tube.
Thoughts?
Byte
Yeah, there's too much play in your throttle cable. Take out some slack using the adjuster by the throttle housing on the bars. But.... I don't think that is ALL of your problem. If giving it a good twist of the throttle makes it "poof" and die, it's likely either dangerously lean or WAYY to rich. Difficulty re-starting would indicate way to rich, unless it is starving for fuel somehow. Float valve sticking closed? Clogged up jets? what mix are you running?
Pull the carb apart and give it a good visual, clean, and re-assemble. It's ok if you've already done this, do it again!
Byte
Post by Byte »
THankS.
Should that steel sheath be attached/connected onto the bent tube (on top of cap)?
I disassembled my carbi 2 weeks ago and cleaned it.
Indications of being too rich?
I am running 40:1 ratio.
Byte
too rich - blubbering/drowning out
too lean - buhhwahhhhhh type of bog
Plug look black and wet when you pull it out? Or dry and white? Somewhere in between?
Sure SEEMS like fuel delivery.
