my stock handlebar dampers are shot
Postby Sky.A » 10:58 am Jan 07 2007
is there any aftermarket dampers ? urathane maybe? or any other suggestions
Kauai Boy 04 kdx 200
Sky.A
Has thanked: 0 time
Been thanked: 0 time
Postby canyncarvr » 03:00 pm Jan 07 2007
Why do you think they are 'shot'?
Mine are seven years old..work fine.
There are other choices. Scotts makes a set. IMO they don't FIT, but they make a set. They are too small, allow the pedestals to tighten against the clamp...so they don't DO anything. I have a set lying around (I think) if you want 'em.
I've looked only a little for suitable auto substitutes. Didn't find any that did NOT need to be 'reformed' some.
But..what's the problem?
canyncarvr
Images: 26
Has thanked: 0 time
Been thanked: 2 times
Postby alistair » 05:35 pm Jan 07 2007
you can get alloy ones similar to this
http://mrmotorcycles.co.nz/store/produc ... cts_id=156
i think that should work hopefully ,thats a local new zealand dealer
Alistair
alistair
Has thanked: 0 time
Postby quailchaser » 08:30 pm Jan 07 2007
Scott's and Applied make Kawi replacement cones. They are some sort of ___prene or ___thane (as in...not rubber or alum :lol: ) They are around $21, if I remember correctly.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
quailchaser
Has thanked: 0 time
Postby Sky.A » 01:04 am Jan 08 2007
my left bar cone is wriggling around tried to tighten but the cone is over deterioted and has play on that side
Sky.A
Has thanked: 0 time
Postby krazyinski » 08:57 am Jan 08 2007
I replace mine every couple of years and the wear is noticeable comparing old to new. new is firm old is squishy. KX, KDX cones are same.
krazyinski
Has thanked: 0 time
Postby Green Hornet » 10:37 am Jan 08 2007
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
Green Hornet
Has thanked: 0 time
Postby canyncarvr » 12:15 pm Jan 08 2007
Re: 'Scotts has them
Those are the cones I got that did not fit...too small.
QC: Do you know if Applied and Scotts units are the same?
I'd be all for some new cones myself...but NOT the aftermarket pieces I've seen.
I ran the Scotts cones for 1/2 a ride. Went BACK to the truck to change them out because they SUCKED! More buzz than NON-bushed bars.
Sky: Deteriorated on an '04? Wow. Must be all the UV over there in the islands...too much sun!!!
canyncarvr
Images: 26
Has thanked: 0 time
Postby Green Hornet » 12:53 pm Jan 08 2007
canyncarvr wrote:Re: 'Scotts has them
GREAT I have them sitting on my Bureau. I thought they looked tiny. ARGHHH
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Green Hornet
Has thanked: 0 time
Postby Indawoods » 01:01 pm Jan 08 2007
That's what she said! :mrgreen:
"People ate cows a thousand years ago for the same reason we eat them now. Cause they are easy to catch.We're not savages,we're´╗┐ just lazy. A cheetah could taste like chocolate heroin. But will never know. Those bastards are fast!!! "
Indawoods
Creator and Founder
Creator and Founder
Has thanked: 0 time
Been thanked: 19 times
Postby Sky.A » 03:03 pm Jan 08 2007
No its not the sun that wore um out. its crashing in these tight Hawaiian trails that did the job on my damper LOL
Sky.A
Has thanked: 0 time
Postby Green Hornet » 03:51 pm Jan 08 2007
Indawoods wrote:That's what she said! :mrgreen:
Hey Vince BITE ME, BIG BOY :butthead: :grin:
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Green Hornet
Has thanked: 0 time
Postby Kawinj » 06:30 pm Jan 08 2007
Try the Applied CR cones. They are denser, more of a nylon composite, have less squish factor and fit the stock set-up.
"The name's Francis Soyer, but everybody calls me Psycho. Any of you guys call me Francis, and I'll kill you."
Kawinj
Location: New Jersey -land of Bruce and overpriced real estate.
Has thanked: 0 time
Postby quailchaser » 06:58 pm Jan 08 2007
I have the ones Scott's sent with the Oversized bar mount kit when I ordered my damper. I had no issues on my KX.
I'd have to agree with Kawinj if the Scott's Kaw cones were too small. The Honda Cones will work fine. I put the Tag oversized honda bar mounts on the KDX with the OEM cones and it worked fine.
As far as whether the cones are the same from Scott's and Applied...your guess is as good as mine...but they look similiar in that they are cone shaped and made out of some sort of ___prene or ___thane. :lol: I've never compared them side by side.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
quailchaser
Has thanked: 0 time
Postby z1nonlyone » 10:45 pm Apr 17 2007
Hi, this is a great subject, I have a stock 05 220 and I notice that my "bars" appear bent after a monor tip over. (Daughters bike). I have Renthal "Twin Taper" bars and I know that they do not get bent. I loosen up the oversize mounts, (stock mounts and bars did the same thing) and I can force the bar back into position. I tighten up the mounts again and away I go. I am not feeling any "cushioning" or allowable movement in the bars at all. Am I overtightening them?? Are my tappered rubber cushions shot? Any good replacement ones?
Thanks,
Chris
z1nonlyone
Has thanked: 0 time
Postby mattR » 07:18 am Apr 18 2007
I have had a set of these in for at least 3 years. Didn't notice any more vibration and the bars don't move like they did with the OEM cones.
97 KDX 220
mattR
Has thanked: 0 time
Ended up getting the scotts also
Postby Sky.A » 11:52 pm Apr 18 2007
they look small but as you tighten them up they snug up just fine .And i love um now all I gotta do is let my ankle heal up so I can go ridding again
Sky.A
Has thanked: 0 time
Postby z1nonlyone » 11:59 pm Apr 18 2007
thanks guys for the info! I just ordered a set and hope they work! I also sent my carb to RB Designs for his magic,,,I have heard that works also!
Chris
z1nonlyone
Has thanked: 0 time
Return to KDX General Q&A
Who is online
Users browsing this forum: Google [Bot] and 3 guests
cron
