Are 98 KX wheels identical to 99-02's?
- bradf
According to bikebandit they are different PN but I see AZ Rick has a 98 0n his 01. So Rick, I take it a 98 wheel will work with my 01 axle?
Ahhhh.
I don't know about that... I bought my forks ('98) and wheel (was it an '01) here at KDXRider.net... but it didin't come with an axle, so I went to eBay and bought the very same year axle as my wheel.
I'd be guessing. Somebody with microfiche or buykawasaki.com might have better info.
Rick
Rick
- krazyinski
yes the wheel is the same but the axel is differant so yes using your 01 axel and spacers you will have a good fit.
The KDX wheel isn't holding up?
- bradf
No. I am continually tweaking it and adjusting. I need a KX wheel. Once I find my KX wheel I'll give away the split collar spacer and axle nut/shoulder that Phil made.Look in his gallery for pics. Someone that wants to run their stock KDX wheel with the KX forks can have em free.
- Colorado Mike
