Installing Grease Zerks
- m0rie
There is a fairly nice writeup on the other site about installing grease zerks on the KDX. This one actually looks like it might work for its intended purpose, as in getting fresh grease to the bearing. Take a look and see what ya'll think.
http://www.dirtrider.net/forums3/showth ... p?p=871251
-Maurice
-Maurice
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
Now now now....let's not start any site bashing....
M0rie....take a deep breath!!! ;)
- m0rie
Believe it or not this isn't my doing. You'll have to ask Inda about that one. I recall him making any links to the dirtrider site change to the megalomaniac you see above.
-Maurice
-Maurice
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
Nah... just a software glitch....
- m0rie
I'm reading...and re-reading...and I'm still missing it.
re: 'Method #1-- used for 3 each paired swingarm bearings & 1 each paired bearing in linkage'
***edit** Removed the question...the stupid, idiotic question. Now I'm going to flaggelate myself. ...where's my stack of cane.....??
**edit
re: Method #3 (lower shock)
That might work OK. He's coming in from the side. Don't know if the seals would give enough resistance to push the grease back thru the bearing and out the other side
re: Method #2. (The 'no space between' method) THAT is pretty straightforward.
**edit
- bradf
My 2 cents on the zerks...if anyone cares...anyone?
Taking the rear assy off and greasing by hand only takes about 30 minutes. I know the bearings are full when I do it by hand. I am also inspecting for wear at the same time. Same goes for the steering head. I see that the poster on that other site did approach it in the correct way by making all the cuts etc., and his way will work. I will continue doing it the old fashioned way where I can inspect the parts.
Now now...like the guy said...he didn't want to start the zerk-or-not argument. ;)
- m0rie
I can see using both zerks and regular tear down greasing to keep the bearings in good working order.
CC - I'm not sure I follow you on the #1 method. I don't see where he drills the sleeve there at all. I'd think that the space between the bearings would fill with grease, then slide out in the space between the bearing rollers and the sleeve, then exit out the output holes?
Method #3 was the one that I wasn't sure would work.
-Maurice
-Maurice
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
Good! If you DID follow...I would be concerned about you. ;)
Can't say why it wasn't clicking a few minutes ago. It wasn't. The temporary blockage has been removed...seems plain enough now. Well..I do know why..two things I was putting together that are not related.
Anyway. I got it. Thanks.
- skipro3
- bradf
Sure. Keeping in mind the whole 'zerk or not' argument...that you don't CLEAN anything without taking it apart, there is no inspection of condition for a couple of things.
Folks that end up taking a sledge and a torch to their swingarm pivot pin don't generally do that because the bearings are stuck to the sleeve but because the sleeve is stuck to the bolt. A grease fitting in the swingarm isn't going to help that a whole lot.
Probably not something you would do with a hand-held drill, 'eh? Note the lathe, drill press and such in the pics..........
imo and all that.......
- Mr. Wibbens
There you go! Talking 'bout me again!canyncarvr wrote: Folks that end up taking a sledge and a torch to their swingarm pivot pin...
I think that having a grease fitting is a good idea, but some people use it as a crutch and do not clean their bearings properly. I think it would be wise to not look at it as a way to get out of actually taking apart the assemblies to clean, inspect and regrease the bearings.
A grease fitting is not designed to bridge the gap between how often they should be serviced properly and how often someone WANTS to service them properly.
Forget the zerks... Get in there and see what is going on with your bike. Tear it down, see whats happening to those bearings and races.... makes you become one with your bike. It seems a lot of people look for the easy way out... that's OK I guess... it's your bike. Some people would probably benefit from the zerks, and then again...some wouldn't even grease their bike if the zerks were there! It's a nice write up but I don't see any real application... except maybe Military where it had to be in service at all times. Let's hope that don't happen!
I don't get to viset here very often but you guys seem pretty good. I also checked out Dirtrider too and they also seem helpfull. I looked up megalomaniac. I don't see why the owneer of this site would change it to something like that. It is not really a nice thing to do.m0rie wrote:Believe it or not this isn't my doing. You'll have to ask Inda about that one. I recall him making any links to the dirtrider site change to the megalomaniac you see above.
-Maurice
jon
I'm not in the military, but my bike is in service all summer ;)Indawoods wrote:It's a nice write up but I don't see any real application... except maybe Military where it had to be in service at all times. Let's hope that don't happen!
Doesn't everyone else ride every single free day they have in the spring/summer/fall? We do.
Phil
jon,
Obviously... you have not met the owner of DRN yet... or else you wouldn't even ask. It's not something you should even bring up here... we are trying to get over it and not stir up old dirt.
All the knowledgeable people that used to be on DRN are here now. Nuff said.
BTW... try mentioning this site over there... see how fast they delete your post!
