Cylinder opinions
Cylinder opinions
I just pulled my 220 cylinder, piston/cylinder show no deep scratches and appear to be in decent shape. However the cylinder walls show a lot of glazing and no visible cross hatching can be seen, pictures:
There also can be seen on the jug (under Reed) to read 3/12 (in pink on left) and I don't know what the other says (in green on right), picture:
I would like some input and opinions if this is normal, and I can scuff it up with oil and scotchbrite pad. Or will this require more in-depth repairs (plating)?
Thanks,
Mario
Thanks,
Mario
- 6 Riders
Re: Cylinder opinions
Plate it! Can't go wrong and will last for years. Plating (nikaseal) is better than the Electroplating that Kawi put on these cylinders to begin with.
It looks like the factory plating may be worn thin in a few places. It is hard to tell without scrubbing the glazing off though. Try scotchbrite pad and some lubriation, then wash it well and post up another pic.
- Jaguar
- Country: Paraguay
why would you worry about it glazing? that just means the rings have matched the cylinder and it is sealing good. scratching it up is only for when you install new rings so they will wear in to match the cylinder.
Cylinder opinions
I thought that glazing was a sign for the cylinder wall coating getting thin. But that's good news then, thanks.
Mario
Mario
How does the typical nikasil replated cylinder last? How many pistons could it handle (provided you change them regularly) before it wears out?
Sent from my ASUS_Z00AD using Tapatalk
Worn? Yes.
Worn out? No.
Where exactly in the middle? It depends on who you ask.
What are you using the bike for?
Can you afford a new piston kit and plating or are you on here asking for a majority to comment and tell you not to spend the money? (it happens a fair amount)
Depending on how often you ride, how hard you ride, etc., it might be a candidate for "ride it one more year" then replate it next winter.
Worn out? No.
- 6 Riders
I could let that go one more year with new rings, but only if I could afford to do the plating. The last "piston slap" i did was on my son's 220, just to get the stock piston out of it. This summer I have my 200 getting an EG 225 kit and a new left hand case, which means full rebuild. IF I can afford it, the 220 will get replated and a new piston.
- Tyl3r
Lots of good info here from you guys that have been around the block a couple of times.
About how much could one expect to pay for Millennium Technologies to re-plate a KDX cylinder?
Also, do you think it would be a good/bad idea to send the KIPS out to them also for their power valve service? I haven't tore into the KIPS yet, so I didn't know if it was worth the $50 bucks to pay them, or if I should just do it myself? I'd like to learn and do it myself, but it would be nice to have a pro do it right the first time...
To the OP - Not trying to post jack or anything, I figured these questions would go along with the theme of this thread, rather than making another
- 6 Riders
I paid $450 for replate, piston kit, top end kit. Did the Kips myself, it sucked. I went through a local shop to get this done. If you go through Millennium Tech yourself and source your piston yourself, it could be cheaper.
Cylinder opinions
Okay, thanks for the info. The cylinder is packed up and getting shipped to millennium. The head is getting shipped to RB. I figure I would do it now since I have the time/money. I took the kips out myself, it really is not that bad at all. I just wanted everything super clean. I already have a new piston/rings and sourced all oem gaskets.
Thanks,
Mario
Thanks,
Mario
- Tyl3r
Nice. Do you mind sharing an approximate cost for the replating alone? I did some more reading on taking the KIPS apart, you are right, it does not seem that bad. I think I will give that a try also.
Cylinder opinions
Yep, I didn't email or call ahead. I printed out there form and filled it out, I checked call with estimate. So when they call, I will let you know.
- Tedh98
I believe that most of the platers list prices on their sites. I know powerseal does.Tyl3r wrote:Nice. Do you mind sharing an approximate cost for the replating alone?
- Tyl3r
Everyone just talks a lot about Millennium, so I was really curious to see what they charged. I checked their site, just gives info, no price. It probably depends on the size and condition of the cylinder.Tedh98 wrote:I believe that most of the platers list prices on their sites. I know powerseal does.Tyl3r wrote:Nice. Do you mind sharing an approximate cost for the replating alone?
- Tedh98
A link to their pricing is on the main pageTyl3r wrote: I checked their site, just gives info, no price.
http://www.mt-llc.com/pricing.php
- Tyl3r
Cylinder opinions
You are sending the new piston with it, yes?MarioM3 wrote:The cylinder is packed up and getting shipped to millennium.
