What I Won So Far
- skipro3
You can still use the clamps. I'm living (still) proof. The upper clamp fits fine. The lower clamp I shimmed with some brass stock. Carver saw them I think. They clamp down just fine too. So head out and buy some brass shim plate, trim to size and slide them together then torque to about 12 or 13 ft lbs.
Jerry
slipro3, are you a gambling man?
- skipro3
Dude. We are talking about Green Hornet's clamps and forks.
- skipro3
Jason,
Are you meaning that I shouldn't suggest a risky modification to make the parts function?
It's a sport where we fabricate many of our own parts or modify to make them fit. The whole KX on a KDX fork setup is a fabrication. Can things go wrong? Sure, that's why we wear a helmet. Ha!!
So it's up to Hornet to assess the risk. I find that shimming the forks to fit the clamps works both in practice and at the engineering level. Lots of other things on my bike are shimmed and they work fine too. Some even designed by the manufacturer that way.
Jerry
What year forks do you have? What year clamps do you have? I thought you got them from the same bike. If so, why do have tin foil shoved down in the clamps?
Green Hornet, good luck with it.
I was thing what Ski said. I think that will work fine, I'll see
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- skipro3
When the fork tubes slide up in the clamps and poke your eye out, I will give you $50 shipped for all the KX front end parts.
Shim-shimanee-shim-shimanee
shim-shim sharee
when you listen to skipro,
you just might D - I - E
Just buy some clamps that fit or shim them and hit a large double with the gas on hard. You will be in perfect position to land front end high and do a big slap down landing so they will fire off like bottle rockets.
Sorry, Green Hornet, it is mostly humor between skipro3 and I.
shim-shim sharee
- skipro3
The bars are over the forks, so IF they did loose grip, the bars would stop my eye from gettng poked. Adjustments to this will be made when you come out for a visit though.
Hornet, let us know how it works out for you.
Jerry
skipro3, if you bought the forks and triple clamps from the same bike, why are you using anything to shim it? I just don't understand that.
Thanks for thinking of my safety on any future visit.
Its such a small difference I takea look when they get here. A 40 ft double . I'll wait for the video to come out. Ski can you post a pic of what yours (Clamps) look like PLEASE
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- Colorado Mike
What color Aluminum Foil should I use, Silver or Gold.
Why does the stem have to be knurled? Does it get damaged during the pressing of the stem? I checked the forks are 46mm, but the area where the TT connects are flanged.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
