pLease help
pLease help
Rubber oil fill plug twisted off what's best way to get the rest out. I'd prefer to not take my bike apart
Living the good life :)
Re: pLease help
I drilled a small hole in mine and stuck a flat headed screw driver in. And backed it out
- diymirage
Re: pLease help
no experience with rubber, but I would try getting a pick in there, as for of center as possible and try to "unscrew" it that way
the real issue will be how tight it is on there.
worst case scenario you get yourself a knife or a dremel and cut it out in pieces
-1997 KDX 220 project bike
- Sullyfam
Re: pLease help
I would either use a Dremel or razor blade and cut a slot in the middle and then use the widest standard screw driver to unscrew it. If using a Dremel be careful not to cut the side of the cover.
- Sullyfam
Re: pLease help
+1 for royadams suggestion.
Re: pLease help
dremel, then penny, nickel, etc. and some PLARS
- diymirage
Re: pLease help
a nickel, sounds like it could get expensiveJason wrote:dremel, then penny, nickel, etc. and some PLARS
- ICRage42
pLease help
I was gonna throw a jab at that but told myself to be nice and you did it anyway rofl.
- diymirage
Re: pLease help
not sure how I ended up with a reputation of being a cheapskate but I figured I might as well play it
