Bearing removal
Dekon
Bearing removal
Post by Dekon »
How do you get the bearing out of the case that you can not drive throught from the other side. Figured since the cases are split, might as well as replace all the bearings and the bushing. Also, what would you recommend from cleaning the inside of the cases? BTW, not only were my crank seals toast, but the main bearing on the clutch side was so bad that it had started to blue from the heat.
kx200
Bearing removal
Post by kx200 »
Dekon
Bearing removal
Post by Dekon »
Thanks, just what I feel like doing, spending another $100 on a tool I'll use once.
Tedh98
Re: Bearing removal
Post by Tedh98 »
There are some other ideas, but take a look at response #5 in this thread: http://www.practicalmachinist.com/vb/ge ... es-188905/
I used plumbers putty to get the blind transmission bearing out of my case.
IDRIDR
Re: Bearing removal
Post by IDRIDR »
Would this work? Cheap, simple, clean. Eat what you don't use.
http://youtu.be/nkRmKWktW70
2003 KDX 220. RB Carb & Head Mods. Desert pipe. She's a runner!
2006 KLX 250 w/351 big bore. A well-sorted dual sporter.
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
Tedh98
Re: Bearing removal
Post by Tedh98 »
Same concept as what I posted above. Bread would have to be one of the last things I would have ever thought to have used. I have heard of people using wet paper towels though.
Dekon
Bearing removal
Post by Dekon »
Thanks guys, I'll give that a shot.
ohgood
Bearing removal
Post by ohgood »
Dekon wrote:Thanks guys, I'll give that a shot.
yes, it will work. a slide hammer is a very cheap thing to make though, and most welders will rig you one up, and weld the cross piece to your stuborn race for $40 or so.
some of the 30" bearings i used to machine / grind bores for had oil grooves ground into their journals. one grease nipple + a mighty badass grease gun = the outer race came out with ease. it's really quite amazing to watch a 300 lb bearing race just lift out of a journal.
Dekon
Bearing removal
Post by Dekon »
Just thought of it, I might try AutoZone for their tool loan, they have a blind bearing puller.
newbbewb
Re: Bearing removal
Post by newbbewb »
IDRIDR wrote:Would this work?
W.T.F. That is frickin awesome in a really ghetto way.
93 kdx200-Highly modified
89 kx125/kdx200E engine
Buelldustin@gmail.com
ICRage42
Re: Bearing removal
Post by ICRage42 »
Yea I would of never of thought of that. Seems to work really well too and no damage to case.
newbbewb
Re: Bearing removal
Post by newbbewb »
I'm gonna have to get a loaf of bread for my toolbox now, just to see the look on the guys faces. seriously, I'm waiting to do a clutch on something now just so I can try it.
Tioli
Country: Tasmania AUS
Bearing removal
Post by Tioli »
Excellent tip.
Bread huh.
royadams
Re: Bearing removal
Post by royadams »
The problem with that is there are not any sealed bearings in a transmission. I bet the bread will just push out through the bearing.
Re: Bearing removal
royadams wrote:The problem with that is there are not any sealed bearings in a transmission. I bet the bread will just push out through the bearing.
not if it is wheat bread
:busted:
Tedh98
Re: Bearing removal
Post by Tedh98 »
I use this approach on this bearing. But I will stick with plumbers putty, much easier to clean-up.
Dekon
Bearing removal
Post by Dekon »
OK, so just for reference, the puller set fom AutoZone was to large for the KIPS governor bearing and the water pump bearing. Used wet paper towel and a couple of different bolts. Took all of five minutes to get both out. The needle bearing, as shown above in Tedh98's post, I was able to use the puller and heat gun to get it out. Just heat the case, three whacks with the slide hammer and out it came. BTW, clean up of the paper towel was easy, it was so packed together, it came out in one solid lump.
Re: Bearing removal
wow!
Cool!
IDRIDR
Re: Bearing removal
Post by IDRIDR »
Thanks for reporting back!
2014 Suzuki DL1000.
