Bars
Brom32
Bars
Post by Brom32 »
I am looking to upgrade to better handle bars mostly because I can't use the bark busters that I got for my birthday.
What Bars do you guys recommend?
04 Kdx200 w/ PC Platinum 2
morganid
Re: Bars
Post by morganid »
I use the Tusk bars. I love the feel, the look, and the price! I'm about ready to put a new set of bars and bark busters on my KDX.
diymirage
Re: Bars
Post by diymirage »
why cant you use the bark busters ?
-1997 KDX 220 project bike
Brom32
Re: Bars
Post by Brom32 »
I have the stock bars and on the throttle side the bar isn't exactly hollow. That meaning that you can't stick the bolt into it. Here's a picture of the bark busters
Brom32
Re: Bars
Post by Brom32 »
jerry malbeck
Re: Bars
Post by jerry malbeck »
cut the very end of the bar off and use a die grinder to smooth out the inside , If you dont have a die grinder use a drill bit .
diymirage
Re: Bars
Post by diymirage »
Your sure the throttle tube is open ended right ?
Re: Bars
diymirage wrote:Your sure the throttle tube is open ended right ?
All it takes to make it open ended is a hacksaw :cool:
Some bars have plugs in the end, if you cant pull it out you may be able to drive it further in so the bolt will fit. Or cut the very end off like above. Or get new bars if you want! Having ridden with a set of oversize bars last weekend, I'm now shopping for my next set! :roll:
KDXohio
Re: Bars
Post by KDXohio »
+1 on tusk bars
elusive
Re: Bars
Post by elusive »
I run the tusk cr high bend bars. I like them.
Bars
I have Tusk bars and they have many different bends available. I run the YZ/WR bend as they measured out the closest to the factory KDX bar.
Gotanubike
Bars
Post by Gotanubike »
I just orderd a MSR dominator YZ high bend bar not too long ago. Still waiting on them but they look good for the price
$40 with free shipping in the U.S
http://www.ebay.ca/itm/301000305455?ssP ... 1497.l2649
1990 KDX200
