Help!!! engine shooting stuff out exhaust, Picture Added
Ok so I walked into the garage the other day and my bike had fallen over, I stood it back up and then a couple of days later started it up but a lot of black liquid shot out the exhaust and gave my buddies quad an oily fuel paint job. My only guess is that when the bike was on its side that the crank oil/gear oil somehow leaked by and rested on the piston. So as soon as I fired it up it must have all shot out, does this sound accurate, not much exp with 2 strokes here. So am I in need of a rebuild or what, will upload pic asap
Edit:
Edit:
I would guess that it just moved the "spooge" around in the silencer/pipe and allowed it to come out in an obvious way. 2 strokes tend to spit normally anyway so I think its probably fine and nothing to worry about. Other than the mess of course...
Re: Help!!! engine shooting stuff out exhaust
The transmission is separate from the top end.
Perhaps the liquid spooge in the pipe shot out or somehow the residual oil pool at the bottom of the crankcase leaked out??
I'm just guna drain the crank oil and refill it, just in case and then let her run for a bit
Don't let it set and idle for too long without air blowing over the radiators.
[quote="Thundergoat"]I'm just guna drain the crank oil and refill it, just in case and then let her run for a bit[/quot
Are you running the OEM Muffler? or a FMF replacement?
Jason wrote:Don't let it set and idle for too long without air blowing over the radiators.
ya ill ride it around
Deseret Rider wrote:Thundergoat wrote:I'm just guna drain the crank oil and refill it, just in case and then let her run for a bit[/quot
FMF
- diymirage
Re: Help!!! engine shooting stuff out exhaust, Picture Added
that seems like a little more then regular spooge
I would check the oil level just to be sure (takes about 12 seconds with the sight glass anyway)
on a side note, I have that same helmet (and matching pants and jersey)
-1997 KDX 220 project bike
Wow, that is a lot.
Can't be your tranny oil.
Was the gas petcock on when the bike fell over?
Well I'll never complain about cleaning drips and runs off my bike ever again!
ya it was more than i figured was normal
i dont believe the fuel was on, im almost positive it wasnt. on a side note I cleaned the shed up in order to overhaul the bike
but ya I havent had time to really check the bike over yet, but i was just basically asking if its possible for oil to come from anywhere up into the combustion chamber like that
- scheckaet
that is a lot.
Could it be gas and oil mixed with antifreeze?
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Gotanubike
First thing I'd do is remove the silencer and start it up, if it's still barfing that stuff up, you know it's not residual oil so I'd skip the oil change and get inside the motor to have a look. If there's a big mess inside the cylinder, you're likely looking at some pretty bad crank issues possibly seals or bearings
Also yeah check your coolant levels. I had a similar looking scenario pictured there, but that turned out to be a crack in the cylinder under the KIPS bottle(KIPS cover), water getting into the cylinder through the expanion bottle port
1990 KDX200
Looks like fuel or water mixed with oil, did it smell oily or gassy? Had you washed the bike recently (could have water getting in the exhaust. At the very least you'll want to repack the silencer and pull the drain plug on it. I'd take the pipe off completely and take a look, as well as checking your coolant level. You weren't this guy, were you?
[youtube][/youtube]
[youtube][/youtube]
bufftester wrote:Looks like fuel or water mixed with oil, did it smell oily or gassy? Had you washed the bike recently (could have water getting in the exhaust. At the very least you'll want to repack the silencer and pull the drain plug on it. I'd take the pipe off completely and take a look, as well as checking your coolant level. You weren't this guy, were you?
[youtube][/youtube]
when it happened i smelled it and it didnt smell sweet so I doubt it was coolant but who knows. once it warms up here ill be brave enough to start tearing it apart, ill make sure to keep this thread updated and add pictures with what I find
I think i found the culprit
it was all in the expansion point
im guessing its fuel
im almost 100% positive it was all fuel and that i must have had the valve open, no coolant was missing out of the radiators.
SON OF A .... !!!!!
That is reallllllllly bad!
Glad you got it out of there.
- scheckaet
one would think your bike has issue having fuel mix leaked into the pipe like that...
bad carb? float and needle come to mind...
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Good point, ive never rebuilt a carb before but what the hell might as well learn.scheckaet wrote:one would think your bike has issue having fuel mix leaked into the pipe like that...
