Even though it's still winter in Idaho, I ride when I can. For now that means on the streets back and forth to college classes. But it gets dark early. I have discovered that my headlight is GREAT for checking the trees for monkeys and not so great at checking the road for ice patches. CAN THE STOCK HEADLIGHT OF A 2003 KDX 220 BE AIMED AT THE GROUND INSTEAD OF THE TREES? Seeing the road would be nice.
Thanks.
PS. Also why is there not a 220a forum in the Model Specific Forum section?
Stock Headlight Aim???
Re: Stock Headlight Aim???
The screw under the headlight is the adjuster. Loosen it it will lower the beam, tighten it will raise it.
I bought a new longer screw and a stronger spring for mine.
- TheJackRabbit
there is no 220 section because the H series 200 and A series 220 are the same with the exception of the topend of the motor
http://www.youtube.com/allthatstuff35 <--- some KDX videos here
I'm smarter than I act
Because it isn't any different than any other KDX manufactured since 1995?PS. Also why is there not a 220a forum in the Model Specific Forum section?
Ah. I see. ThanksTheJackRabbit wrote:there is no 220 section because the H series 200 and A series 220 are the same with the exception of the topend of the motor
Awesome. I found the screw walking by my bike. When I get some time, I'll play with it.royadams wrote:The screw under the headlight is the adjuster. Loosen it it will lower the beam, tighten it will raise it.
THANKS!
Found the screw and adjusted it. The previous owner had it 100% screwed in I think that squashed my spring flat. I think I'll be getting another spring in the future.
