Anyone running Polisport MMX headlight ?
- ihatefalling
THinking about getting one. Wonder if it'll mount up ok. Comes with those rubber mounting straps. I have a WER. Thanks for feedback . . .
http://www.polisport.com/produtos.php?I ... D_ORG=644#
2005 KDX 220
R&B Carb Mod
R&B Head Mod
Fork Swap - 99 KX125 Valved for B woods plush
FMF Gnarley
Airbox Mod
Tagged
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
- Varmint
- ihatefalling
- ihatefalling
Update....I got one of the Polisport MMX headlights.....in white
Pretty easy to install. The aim was naturally too high so I had to fab just a minute to get the aim down....no biggie.
The only think of note is: the connectors on the headlight are male spade connectors that are really skinny. I guess normal spades are 1/4 or something....these are like 1/8.
So what do you think of the white? I bought it b/c it was $7 cheaper than green.........
2005 KDX 220
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
- ihatefalling
ha....just put it on 10 minutes ago.........so far so good
Oh yeah.....the beam is reasonably good. Probably the same light output as the stocker, but it seems to be dispersed a little more.....so not quite as bright, but a little wider beam........same difference probably
2005 KDX 220
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
looks good on the bike I must admit hat I had been told that the coil would not power this light, I might have a look at one of these for mine.
Been riding off road for 10 years still finding out how best to do it.Riden a DR125 then a DT125R then a DR125 then DRZ400 then XR250 then a TE610 now I hope that I have found the best a KDX220 just to add the KDX has gone now riding a WR426 which I love and is so much better than the KDX.
- ihatefalling
Update......been on a few rides with the new light. Has held up just fine. The rubber mounts make it just a touch "movey" if that's a word, but it's no big deal at all. Haven't needed it at night. The light would get you out of the woods but I wouldn't run any rallys with it.
2005 KDX 220
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
I have one on my bike too, I didnt use the plastic shims and I also had to put some small plastic pieces in behind the upper straps to aim it down. But the light is way better then my buddy jays stock 98 220 light. We compaired lights the other night when we rode late. My coil lights it just fine and I wired in both high and low beam together one issue I had was the small light in the top corner fell out so I would suggest siliconing it in. Mine is lost and gone forever :-(
FYI, you can get 45 and 60 watt bulbs that fit the MMX. I'll be trying both when I get my 200 done however I will be running a higher output stator.
- ihatefalling
Re: Anyone running Polisport MMX headlight ?
Sorry to comment on an old post. Do you still like the headlight? I just got a 2003 KDX 220. I Have the stock headlight but I"m looking for a headlight that has a high/low beam on it. Does this headlight do that? I want to make my bike street legal so I'm starting to look at parts and what not I'll need. Thanks.
- 6 Riders
The "Tusk Dual Sport kit" from RMATV as the best way to go with this, and then a new dual pole socket for your stock headlight, which you should be able to find at a auto parts store. The stock bulb is already a hi/lo bulb, just no switch and a single pole socket.morganid wrote:Sorry to comment on an old post. Do you still like the headlight? I just got a 2003 KDX 220. I Have the stock headlight but I"m looking for a headlight that has a high/low beam on it. Does this headlight do that? I want to make my bike street legal so I'm starting to look at parts and what not I'll need. Thanks.
- Mayor Brap Brap
I am thinking of the Tusk Dualsport kit, but I already have the UFO Sahara headlight and UFO taillight with bulb. My question is this: how can I convert the UFO headlight and taillight to LEDs? Would I search for an LED socket? How would I know what voltage/wattage/etc. to find? Thank you!6 Riders wrote:The "Tusk Dual Sport kit" from RMATV as the best way to go with this, and then a new dual pole socket for your stock headlight, which you should be able to find at a auto parts store. The stock bulb is already a hi/lo bulb, just no switch and a single pole socket.morganid wrote:Sorry to comment on an old post. Do you still like the headlight? I just got a 2003 KDX 220. I Have the stock headlight but I"m looking for a headlight that has a high/low beam on it. Does this headlight do that? I want to make my bike street legal so I'm starting to look at parts and what not I'll need. Thanks.
-An Electrical Idiot
- 6 Riders
With the tail light, you just buy a red led 1157 bulb, pretty simple. As far as the headlight.....I've been searching and only came up with one thing, but I have to order it from China and I'm not ready to do that yet.
