Transmission Poll
What fluid do you use in your transmission?
Conventional 10w30
1
3%
Conventional 10w40
7
21%
Blended 10w30
1
3%
Blended 10w40
0
No votes
Synthetic 10w30
1
3%
Synthetic 10w40
3
9%
ATF
20
61%
Total votes: 33
sailorcolin
Transmission Poll
Post by sailorcolin »
I am having clunky transmission shifts and was wondering what fluid you all run.
sailorcolin
Transmission Poll
I am currently using conventional 10w40.
Goofaroo
Re: Transmission Poll
Post by Goofaroo »
None of the above. I use either Hondaline or Silkolene 80/85 wt.
KDXohio
Post by KDXohio »
None of the above i use gold spectro 80 or 85 wt
sailorcolin
How do yall like the 80/85 wt oil? Hows it feel and how long have you been running it?
sailorcolin
I just switched to AFT an hour ago and I love it so far. Smoother shifts! However I did find out the owner before I stripped the drain plug hole :/ So soon enough I will be draining the oil again. So before I put in new oil I was wondering what you guys were running and what brands!
Goofaroo
Post by Goofaroo »
It would never occur to me to use ATF or 10w40/10w30 "motor oil" so I can't say anything about that. I can however tell you that I have never used anything except oil designed for a 2 stroke transmission and I have never had any failures and the clutch action has never been a problem. My trannies have always been quiet and smooth shifting.
I used nothing but Spectro for years and years but I can't find it around here anymore. That would be my first choice if it was available but I haven't had any problems with the Hondaline or Silkoline.
sailorcolin
thanks!
rbates9
Transmission Poll
Post by rbates9 »
Probably the best thing I had ever used was the Spectro 80? gear oil that I found in the back of my oil shelf from about 15 years ago. But I haven't been able to find it again. And after I changed the oil I tossed the bottle so I can't even remember what variation it was exactly. :doh: But I have had good luck with ATF type F. It doesn't seem to last as long as the Spectro did but the other Spectro oils I have used didn't last any longer then the ATF. I have found that if they label it as any type of "Gear saver" or "Clutch saver" oil it isn't worth a sh!t and cost WAY too much for a one ride oil.
adam728
Post by adam728 »
Shell Rotella 15w-40 us a great low cost oil, and is JASO-MA approved for wet clutches.
ATF is a good choice as well, it is designed for a box full of gears and clutches.
Sent via morse code
Trackdog
Post by Trackdog »
I'm finding this a little confusing.
Every manual I have calls for 10W-30 or 10W-40. Doesn't specify "engine oil" or
'transmission fluid"
I see trans. fluid comes in 10W-30, 10W-40 and 80W/85W. I see Type F trans. fluid on the shelf, but with no weight specified.
Hence the confusion.
My local Kawi dealer, who races the KDX, sold me Pro Honda HP Trans SAE 80W/85W for my 2005 KDX 200
2004 KX 125
1986 CR 125
1994 DR350
1998 VFR
2004 DUCATI S4R
Gear oil, 80 weight is equivalent to 10w-40, according to Bel-ray.
Amsoil oil 10w40 dirt bike oil for the trans.
