New to dirt bikes, in NEW ORLEANS...
Hi all!
Just picked up my 1996 KDX 200 by trading an sks rifle for it..... I'm super excited!
already bought the manual, new air filter, replaced fluids, spark plug, etc..........
I love this site and thank everybody for their input.....
Oh, and WHODAT!
Oh, and WHODAT!
- Postigo
Re: New to dirt bikes, in NEW ORLEANS...
Welcome, please share some photos
- Postigo
Wow is a stock barney bike!! She looks good
- KDXohio
Looks like a pretty good trade!
I must say so myself!!!!
i still need to clean the carb.....i have the manual, but it isnt real specific i dont think....Idk, im a 2 stroke newbie....I dont wanna mess it up ....is it easy? I assume I have to remove the seat and tank...but when i removed the tank the first time to change the spark plug, i noticed that my fuel constantly drips out, even when its in the off posisition.......
You may need a new o-ring/gasket in the petcock.
You have a good start there.
- Postigo
Yep, you need a petcock kit. Its a cheap and easy thing to repair. Make sure to clean the inline gas filter (mesh) located in the upper side of the petcock.
Soooo today was the first day I really got a chance to ride her......Wow!!! What an awesome bike.....5th-6th is feels pretty high up.....60-70mph?? i dont need to go that fast....Would like some more power in 1st and 2nd.....
Overall, I love her....what a great trade for me!!!
- diymirage
nice
I have two of those and they both get up to about 70-75 MPH, defiantly faster then I need to go in any wooded area, but one of mine is plated so the top end comes in handy in the street ;)
as for cleaning the carb, I do it without removing anything other then the carb
first of, disconnect the fuel line
then loosen up the clamps on both sides (intake boot and air box boot) and pull the air box boot towards the rear fender
it has a little bit of a harmonica shape and if the rubber isn't too dry you should be able to pull this back with ease
this should give you enough room to pull the carb out of the intake boot (you can twist it a little bit but there is a sort of keyway molded into the carb (you'll see it when it comes out) and it might catch on there
now the carb should be hanging on the side of the bike attached only by the gascable
unscrew the cap of the carb and slowly pull the slide out
now you're ready to clean her and put her back together (but since you've come this far you may aswell replace the reeds
-1997 KDX 220 project bike
- rbates9
You should also be able to remove the spark plug with out removing the seat and tank.
- diymirage
rbates9 wrote:You should also be able to remove the spark plug with out removing the seat and tank.
yeah, but I wasn't gonna do a write up on that for him
"pull plug cap off, put socket on plug, insert handle and turn counter clockwise, adjust handle and repeat until plug is out"
- KDXohio
This helps but then how does one put said spark plug back in????diymirage wrote:yeah, but I wasn't gonna do a write up on that for him
- diymirage
you don't, you replace it with a fresh oneKDXohio wrote:This helps but then how does one put said spark plug back in????diymirage wrote:yeah, but I wasn't gonna do a write up on that for him
- Postigo
If you want more power a cheap and easy mod is to install a 12 tooth front sprocket.DatmanTshirts wrote:Soooo today was the first day I really got a chance to ride her......Wow!!! What an awesome bike.....5th-6th is feels pretty high up.....60-70mph?? i dont need to go that fast....Would like some more power in 1st and 2nd.....
thanks for all the help guys! what does replacing the reeds do?
- diymirage
new (high performance) reeds will give you a crisper throttle response
and guessing they are 20 plus years old, they could probably stand to be replaced anyway ;)
