New KDX owner from CT
I recently purchased a 1988 KDX200 for $450. Runs great the po said he did a top end on it (im a little skeptical) as i think i got the bike for a steal. But anyway i just replaced the air filter, spark plug, trans oil and bled the front brake as it was sticking. Will do the fork seals as well and get the trip computer working. Any other advice to get this machine in order for riding would be great! I would also like to mention that i am new to the dirtbike scene coming from mountain biking. I'm now hooked!
Re: New KDX owner from CT
Welcome to the forum.
Congratulations on your KDX.
Please post some pictures, if you can.
Pictures...
The bike was blocking the boat. WAIT! Were you trying to show the bike? Got any pics besides the wallet sized?
It was indeed of the bike the boat is just the backdrop . The boat should be in the water by now, even small boats are never ending headaches! Im new to the site and photobucket, are the pictures not showing up full screen? They do for me. I will post some more and try and enlarge them.
Welcome to KDXRIDER! I took the liberty of fixing the pictures in your post. Looks good! Well, it could, with some TLC... A good solid start, anyway!
Pardon me, but:
LUCKY BASTARD!
You have some cool parts there.
That is a white model that someone has put a lime green tank, side panels and front fender on.
SHOW OF HANDS for recognition of the handguards...ANYONE??
LUCKY BASTARD!
Thank you for editing the pictures! i will post up more as i go through the bike. Hopefully i wont find any bad surprises! And yes the hand guards are a plus!
I am curious to see if anyone else can recognize the handguard brand and model.
- Toms220r
Mount up a good set of tires...you'll need them in the roots, rocks and mud of New England!kdxrick wrote:I recently purchased a 1988 KDX200 for $450. Runs great the po said he did a top end on it (im a little skeptical) as i think i got the bike for a steal. But anyway i just replaced the air filter, spark plug, trans oil and bled the front brake as it was sticking. Will do the fork seals as well and get the trip computer working. Any other advice to get this machine in order for riding would be great! I would also like to mention that i am new to the dirtbike scene coming from mountain biking. I'm now hooked!
Where are you located in CT? There's a few KDX owners that ride regularly at the Thomaston Dam, sometimes on their KDX's!. The Pathfinders MC maintain the trails there and are a great group of guys. Come ride with us!
Current Bikes
2001 KDX 220R
2013 250 xcw
2013 TTR 230
2000 XR 70
2004 R1100s
2009 XR1200
2009 XB9SX
2011 KVF 360
Current Bikes
2001 KDX 220R
2013 250 xcw
2013 TTR 230
2000 XR 70
2004 R1100s
2009 XR1200
2009 XB9SX
2011 KVF 360
They look really familiar and I beleive they are preiod correct for the bike. Acerbis or MSR would be my guess.I am curious to see if anyone else can recognize the handguard brand and model.
The bike looks great. I would just service it up and get it dialed in. The white and green plastice suits it nicely.
I recently freshened up a 87 model and it's a great bike.
http://www.frpoffroad.com/Fredette-Raci ... Id=-153379
original handguards for FRP Handsavers
I think I bought mine from him in 1992.
I live in old Lyme right on the shoreline at the mouth of the Connecticut river. About an hour north of new haven and 30 minutes south of Mystic. I plan on replacing both tires and also am still working out the front brake. After about 20 minutes of riding it starts to clamp slightly to the point where you can barely role the bike? After about 15 minutes it lets go. I bled it 3 times so i guess im going to have to take the mastery cylinder and caliper apart and clean/replace worn parts. Also the hand guards do say acerbis on them.
Oops. Yes, they are made by Acerbis (ahhhh-chair-bees).
They came with cold weather plugs for the vents and plugged into the holes by the vents.
The fluid and dust seal may be shot in the caliper.
Look on www.kawasaki.com on the left side for OWNER INFO / PARTS DIAGRAMS, the use the system to select your model and you can see the parts diagrams to see the "microfiche".
Thanks for the info! Also the bike calls for a b9es plug in the manual but had a b7es installed. Could there be a reason for this or did the previous owner just throw in something he had laying around?
UGH! Take that plug out. Go buy an NGK B8ES. It should be under $3 after tax at an auto parts store. Down here, we have O'Reilly Auto Parts. I buy most of my NGK plugs from them.
I will be bold and predict that a "9" is too cold of a plug for your riding terrain and skill level. If you ever move to Arizona and become a desert rat, then you can try the "9". The problem is that the plug will not retain enough temperature to burn off the carbon deposits. It is supposed to be somewhat cocoa brown. On my 1987 KDX200 and 1994 KDX200, I had to go down to an "8".
If you want to play "paranoia", then the 7 is to cover a leaking right crankcase seal, which may cause a standard temp plug to foul. Just try an "8" first, though.
Thanks for the heads up! Hopefully the crankcase seals are good, i will try the b8es and report back.
Also i was running around for an hour or so yesterday with the b9es installed. No fouling issues. Im going to pick up the b8es today and put it in as well as check the color of the b9.
Sounds good.
Let us know how it goes.
Im having trouble finding a gas cap, the one on the bike is cracked and this was apparently a common problem. Would the gas cap from other Kawasaki or even other brand bikes work?
