Kickstarter Only Catches Some of the Time
When I try to crank my KDX250, the kickstarter only catches some of the time. Sometimes it will catch and kick over normally, but then sometimes it will blow right through the kicking stroke. I know this has probably been discussed in the past, but can someone give me a refresher on what causes that? Is it the spring, a gear or what??
Thanks.
Thanks.
I wish you would have said spring. It is cheaper.
ONE VOTE SPRING!!
- m0rie
Contaminated oil or the wrong weight (too heavy) oil in the clutch case will cause the kicker to slip as well.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
I WISH it was only that. I bought a BUCKET! I should put white and red stripes on the side panels and KFC as my number. I am planning to take some "BEFORE" pictures later tonight and post them to my gallery.
- m0rie
Saturday, two days ago
It cranks, it runs, it stops (kinda, kinda, kinda) and it has a shiny pipe and shiny silencer, what else do I need?
- m0rie
Cool. Time to add all the KX swap over stuff for that model to your list(s).
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
Can you explain that a little bit? Do you mean stuff from a KX that will fit on the KDX250 or are you referring to a KDX to KX fork swap??
Like KAY DEE EXER, I Now have "THE LIST".
I think I burned a hole in buykawasaki.com.
You dog! You did tell anyone you bought a KDX250!
I updated my Profile. That is about as "LOOK AT ME!! LOOK AT WHAT I GOT!!" as I got with it.
- KDXer
Encourage him to join this website and post some pictures.
Where's those pics Jason?
I know. I know. I have been working on a computer, which makes money to be fed into the lime green cash eating machines. It will be about 30 minutes or so.
EDIT: Wait. That sounds like I am working on an ATM. It's the "me working" part that I was talknig about.
It's the "me working" part that has me confused!
OK, here are two pictures. Dislaimer: I told you it was in rough shape. These are the "BEFORE" pictures.
http://kdxrider.net/forums/modules/albu ... 50Left.jpg
http://kdxrider.net/forums/modules/albu ... 0Right.jpg
- m0rie
It doesn't look too bad. A little spit and polish and she'll be good to go.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
