My cylinder looked much worse than his when I sent it off to Langcourt and it didn't need a bore.zepplin153 wrote:I believe "Single cylinder bore, plate & diamond hone (aluminum or cast iron) $209.95"terminatr wrote:Does the studs need to be removed before sending to Langcourt? If so, how do I remove them?
I just bought a standard size Wisco 220 piston. After I get the cylinder back from Langcourt, can I still use this Wisco piston?
What instruction do I need to give Langcourt?
Langcourts' price list:Single cylinder replate & diamond hone (aluminum or cast iron) $174.95
Single cylinder weld bore damage (aluminum only), replate & diamond hone $229.95
Single cylinder repair detonation, replate & diamond hone (aluminum only) $249.95
Single cylinder rebuild damaged skirt, replate & diamond hone (aluminum only) $249.95
Because you want to remove any imperfections and then re-plate. Plus that seems about right on price. you can anticipate another $50 in shipping.
They can lay on the plating pretty thick if they need to so unless you have deep gouges it will probably only be $175.
Also, you can ship it there in a $10 flat rate box and they shipped it back for $22 plus $3 for $300 of insurance.
