91 fork
91 fork
does anyone kno where i can find a thread or site that has someone who made fork guards from pvc? i want to add protection to the forks but just dont know how to mount them to the fork tube. putting kx forks on are out of the question dont have the money for that and didnt like the rubber boots on the forks from oem.
You could get one of those number plates of the older RM125/250 that had upper fork guards built in.
http://www.ebay.com/itm/RM125-SUZUKI-19 ... 79&vxp=mtr
Like that. Of course, you sacrifice your headlight.
Improvise, adapt, and overcome!
Sorry, I don't know the website your looking for but you should be able to figure it out fairly easy.
Large zip ties or hose clamps.
dnovack wrote:i think i found a way to do it. i was reading a thread last night about a guy who took pvc slit the back of it and snapped it on the fork tube. think im going to try it. need to measure the fork tube and get myself some pipe.
Lets think about this. PVC snapped over the fork tube... You looking to eliminate your suspension travel? I can't picture how that would work. It has to be secured to the lower fork or the triples, not on the inner fork tube.
- rbates9
The PVC will end up being pretty short after you take out the compression distance. If you already have the stock boots off than go jump it or try some other way to FULLY compress the forks and see how much distance you have from the top of the lower tube to the triple clamp.
Have you considered seal savers?
If he uses a coping saw to contour the upper portion of the pvc pipe into a simple shield, but keep the bottom 2 inches pipe-shaped with a slit, then the bottom two inches would snap around the lower fork tube and the shield would be positioned in front of the upper tube. It still might want to bash into the side of the headlight, so some trial and error would be necessary to get the shield shape right.
David Eckel
- Mr. Wibbens
protecting something that does not need protecting
$#@& you n00bs kill me
