Wiseco Clutch baskets for 95+, group buy opportunity
hi_im_sean
Post by hi_im_sean »
all of the 95+ owners knows that no one make a clutch basket for us, and the stock cast one sucks.
wiseco has agreed to do a small run, if i can get 10 people together or more, they will do it. the price will be less than $200 for a new forged clutch basket. please go to TT and post if you are interested.
http://www.thumpertalk.com/forum/showth ... p?t=994373
thanks!
spaun
Post by spaun »
Does this also fit d class 91-94 Kdx 250s?
hi_im_sean
i couldnt tell you, but i would think the 89-94 kdx200 basket should fit that bike, wiseco makes those baskets already.
David_L6
Post by David_L6 »
BUMP!
Let's get this done while we can.
Ya I replied on thump-r-talk
dfeckel
Post by dfeckel »
You can make the 95 and up baskets work with the 89-94 bikes, but you need all the ancillary clutch parts, including plates, hub, pressure plate, springs, etc. You basically need the WHOLE clutch assembly. The only thing I'm not 100% sure on is whether the earlier cover is deep enough to fit over the later assembly.
David Eckel
David_L6
Post by David_L6 »
Slick_Nick wrote:Ya I replied on thump-r-talk
Thank you!
spaun wrote:Does this also fit d class 91-94 Kdx 250s?
Sorry but it doesn't fit. The KDX200 and 220 are based off the KX125 engine where the KDX250 is based off the KX250 engine. The basket for the KX/KDX250 is quite a bit larger than the KDX200/220,
SCREAM
Post by SCREAM »
ok, I replied over there so hopefully this gets done. I'm in the middle of a rebuild so this is perfect timing for me
