Does a modded 200 wheelie through 6 gears?
- 2001kdx
I have a stock 200, but it seems 6th gear doesnt make enough power to hold a wheelie. 5th gear has a nice, long top end pull, and I can go 500-600 feet pretty easily, but 6th gear has nothing. Do the mods help the higher mph power?
- skipro3
- stringburner
- radonc73
- krazyinski
a well schooled rider in the stunt biness could, but if my KDX Has the front wheel off the ground in all 6 gears its because I am stuck under it wiggling and hitting the shifter trying to get out from under it.
Green Hornet
when the front wheel is spinning, it acts as a Gyro, enabling you to hold the front up longer. In 6th gear you have some speed going, but I would guess the front wheels rpm are slowing causing you to drop the front end. The point where you feel like you will flip over is the point of center for a wheelie. Does that make sense
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- Jeb
- 2001kdx
