About to Start
- jstcraig
- Country: Australia
About to Start
The princely sum of the fuel for the trip to get the two of them, do the 91 they said will be easier than the 83 [emoji23][emoji23]
A leak/weep Same same [emoji1303]
Sent from my iPad using Tapatalk
- jstcraig
About to Start
Well I would up load a video of the beast running but it won’t let me,so it runs not very well but it runs, only runs with the choke up so the carb rebuild was a fail, and the rattle from the engine is not good, sounds like loose timing chain.
I still nursed it up the street and back between showers so the clutch and g/box is good.
The suspension is shagged but livable but the motor rattle is not good [emoji20]
- jstcraig
Re: About to Start
Have a listen to this, you might get a laugh out of it,
- jstcraig
About to Start
This was the first run, just learning how to upload so forgive the second vid
Re: About to Start
My computer just tries to save them??
- jstcraig
Re: About to Start
don't suppose you looked at the vid ???
Re: About to Start
When I click on the links, my computer tries to save the files, not view them.
- jstcraig
Re: About to Start
Oh, so I jst watched a few different vids on YouTube and the noise that was tripping me seems to be stock across all of them, it has been a long time since my Kx/Rm days, will have another run at the carb to day, another run through the cleaner won’t hurt it
- jstcraig
Re: About to Start
re did the carb set the needle one notch leaner and wound the needle jet out one turn, float height is 19mm, runs with out choke but the idle is inconsistent and difficult balance, it seems to lean now so I will lift the needle one space then try again.
- jstcraig
About to Start
Kips Rattle [emoji849] maybe I should have read some more posts before I worried about that noise hopefully
Ok lifted the needle one notch and it’s better still has inconsistent idle but it improves as it gets warm. Now to sort out the petcock, wish they left enough room for a inline filter.
