I am a supporting member.
Do I need to be a little more supportive?
Thank you,
David
Why cant I post an Avatar?
- Fatherof2
Re: Why cant I post an Avatar?
No sir. Your current support is sufficient to earn that privilege. I will check your permissions right away.
I forgot to post back. I believe your permissions are correct now. Let me know if you have any further troubles. Thank you for your support, by the way!
Jason
Jason
- Fatherof2
- Velocity_Stack
Figured I'd post here with the same problem.
Mine says: The avatar functionality is currently disabled.
Maybe I'm missing something in the settings.
Velocity_Stack wrote:Figured I'd post here with the same problem.
Nossir, that's my bad. It should be fixed now. Sorry about that!
- Velocity_Stack
Thank you Sir.
Works great!
Now that's what I call fast service!
Works great!
Mine says the same as Stack's did.....
"Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing."
PM, Avatar, Gallery, all reserved for supporting members.noshoes wrote:Mine says the same as Stack's did.....
Thanks!
Jason
