I want to swap out my rear brake pads, however one of the pins has been stripped by the previous owner and I've tried drilling etc with no luck.
Do you have any tricks to try before I just drop it in to the shop?
Cheers
tucker
Re: Stuck rear brake pin
Posted: 05:11 am Oct 15 2018
welcome
have you tried heat and penetrating oil, too?
Posted: 08:41 am Oct 15 2018
by Julien D
Had the same problem with my 89 originally. Buggered it so bad trying to get it out that I ended up replacing the rear caliper.
Posted: 12:02 pm Oct 15 2018
by 6 Riders
I used an EZ-out. Drilled a pilot hole, then went to the EZ-out. I replaced my pins with the set from rmatv that have a standard hex head.
The pins need to be lubed too.
Posted: 07:27 pm Oct 15 2018
by Molly's 70
Penetrating oil & 24 hours can do wonder's. Liquid wrench, Kroil, or my favorite, 50 /50 mix of acetone & transmission fluid.
Posted: 10:38 am Oct 17 2018
by Tyl3r
Can you put some vice grips on the pin portion, that goes through the pads? Maybe you can clamp onto that and rotate it out?
Posted: 02:16 am Oct 20 2018
by ScruffyDroid
tucker wrote:Hi guys
