98 KDX 200 lost compression
Re: 98 KDX 200 lost compression
How many minutes is on that plug?? No color does not look good.
Well, it just blew up again. Not sure what exactly happened but I’ll pull it apart and try and find out this week.
No, there wasn’t a whole lot of time on the plug.
Sorry to hear it blew again. If you can, do a leak down test before you tear it back apart. You likely will know why it blew up from that. The jetting you were running shouldn't be so dangerously lean. I'm thinking it had a good size air leak and if you find it now you can double check the same area with another leak down when it goes back together.
Yeah after blowing a second time I’m afraid that it’s got a decent leak.
Yes, likely you have a blown left crankseal. Anytime you do a compression check or suspect engine issues you should also do a leakdown (on 2Ts) check as it is a better indicator of engine health than just compression alone.
