front brake and clutch lever bolts
- Country: usa
Is there a KX bolt p/n? that fits the 2003 kdx levers ??
Re: front brake and clutch lever bolts
Welcome to kdxrider.
Is there something different about the KX bolt that you might want?
- Country: usa
Yes it does not hold the plastic hand guards
- Tyl3r
What bolt are you talking about? Not sure how to help here...
Pivot bolt I assume
- Country: usa
pivot bolt is a good description
the bolt that holds the lever in the perch
- Tyl3r
The bolt that holds the lever onto the perch, I'm pretty sure its an M6x10mm (item 92001?) https://www.partzilla.com/catalog/kawas ... /handlebar
No, that is the bolt that attaches the handguard to the pivot bolt. If you are looking for the pivot bolt without the extra bit that sticks up for the handguard to bolt to you want 92150-1451.
- Molly's 70
Man, That's some good help. Thanks
- Country: usa
What year and model bike has the 92150-1451 ?
Kawasaki ATV 2008 KFX450R - KSF450B8F FRONT MASTER CYLINDER
Kawasaki ATV 2008 KFX450R - KSF450B8FA FRONT MASTER CYLINDER
Kawasaki ATV 2009 KFX450R - KSF450B9F FRONT MASTER CYLINDER
Kawasaki ATV 2009 KFX450R Monster Energy - KSF450B9FB FRONT MASTER CYLINDER
Kawasaki ATV 2010 KFX450R - KSF450BAF FRONT MASTER CYLINDER
Kawasaki ATV 2011 KFX450R - KSF450BBF FRONT MASTER CYLINDER
Kawasaki ATV 2012 KFX450R - KSF450BCS FRONT MASTER CYLINDER
Kawasaki ATV 2013 KFX450R - KSF450BDF FRONT MASTER CYLINDER
Kawasaki ATV 2014 KFX450R - KSF450BEF FRONT MASTER CYLINDER
Kawasaki Motorcycle 1991 KX80 - KX80-R1 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1991 KX125 - KX125-H2 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1991 KX500 - KX500-E3 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1991 Big Wheel - KX80-T1 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1991 KX250 - KX250-H2 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1992 Big Wheel - KX80-T2 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1992 KX125 - KX125-J1 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1992 KX250 - KX250-J1 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1992 KX500 - KX500-E4 Front Master Cylinder(KX500-E4/E5)
Kawasaki Motorcycle 1992 KX80 - KX80-R2 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1993 KX125 - KX125-J2 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1993 Big Wheel - KX80-T3 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1993 KX250 - KX250-J2 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1993 KX80 - KX80-R3 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1993 KX500 - KX500-E5 Front Master Cylinder(KX500-E4/E5)
Kawasaki Motorcycle 1994 KX500 - KX500-E6 Front Master Cylinder(KX500-E6/E7/E8)
Kawasaki Motorcycle 1994 KX125 - KX125-K1 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1994 KX80 - KX80-R4 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1994 Big Wheel - KX80-T4 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1994 KX250 - KX250-K1 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1995 KX250 - KX250-K2 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1995 KX100 - KX100-B5 Front Master Cylinder(KX100-B5/B6)
Kawasaki Motorcycle 1995 KX80 - KX80-R5 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1995 KX125 - KX125-K2 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1995 KX500 - KX500-E7 Front Master Cylinder(KX500-E6/E7/E8)
Kawasaki Motorcycle 1996 KX125 - KX125-K3 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1996 KX100 - KX100-B6 Front Master Cylinder(KX100-B5/B6)
Kawasaki Motorcycle 1996 KX500 - KX500-E8 Front Master Cylinder(KX500-E6/E7/E8)
Kawasaki Motorcycle 1996 KX80 - KX80-R6 Front Master Cylinder(KX80-R6)
Kawasaki Motorcycle 1996 KX250 - KX250-K3 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1997 KX100 - KX100-B7 Front Master Cylinder(KX100-B7)
Kawasaki Motorcycle 1997 KX125 - KX125-K4 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1997 KX80 - KX80-R7 Front Master Cylinder(KX80-R7)
Kawasaki Motorcycle 1997 KX500 - KX500-E9 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1997 KX250 - KX250-K4 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1998 KX500 - KX500-E10 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1998 KX125 - KX125-K5 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1998 KX250 - KX250-K5 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1998 KX100 - KX100-C1 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1998 KX80 - KX80-W1 FRONT MASTER CYLINDER
Kawasaki Motorcycle 1999 KX500 - KX500-E11 FRONT MASTER CYLINDER
- Country: usa
92151-1103 clutch bolt
- Country: usa
Looks like any KX 1997 to 2018 will work
- Tyl3r
haha wow, I don't know why I said that. My bad, thanks for correcting that.bufftester wrote:No, that is the bolt that attaches the handguard to the pivot bolt. If you are looking for the pivot bolt without the extra bit that sticks up for the handguard to bolt to you want 92150-1451.
