Hard starting after letting bike sit
This area is for KDX 200 H series part numbers etc...
Postby bergilong » 05:13 pm Aug 08 2017
If I let my KDX sit for a week or two it becomes extremely difficult to start. After I get it to start up, I will be able to easily start it again. Does anyone know what might cause this problem?
bergilong
Has thanked: 3 times
Been thanked: 0 time
Re: Hard starting after letting bike sit
Postby Jason » 06:23 pm Aug 08 2017
Do you use ethanol based gasoline?
Do you turn off the petcock and run most of the bowl out before cutting the engine off?
Thank you, Julien D for all your hard work!
PLEASE! Do not "dip" PWK Keihin carbs in Berryman's to clean them! It will damage the internal o-ring (jet block gasket).
Jason
Images: 13
Has thanked: 92 times
Been thanked: 318 times
Postby SS109 » 06:45 pm Aug 08 2017
The carb bowl is empty. I run ethanol and run the bowl nearly dry after a ride. Next ride I turn on the petcock, tip bike over till it pees out the overflow line, bring it back upright, pull choke, and start it. :supz:
AZ State Parks OHV Ambassador - Trail Riders of Southern AZ
'11 GasGas EC250 Race
Images: 10
Has thanked: 52 times
Been thanked: 79 times
Postby thirdgenlxi » 07:45 pm Aug 08 2017
When mine did that it was the float valve in the carb... Put a new one in and started first kick almost every time after that
thirdgenlxi
Has thanked: 2 times
Been thanked: 42 times
Postby thirdgenlxi » 07:47 pm Aug 08 2017
Can try leaning it over to the side and drain some gas out of the carb before trying to start it and see if the prob goes away. Or shut the gas off just before you shut it off, and see if it does it the next time
thirdgenlxi
Postby bergilong » 08:20 pm Aug 08 2017
Jason wrote:Do you use ethanol based gasoline?
I do use ethanol gas, but I drain the bowl nearly empty before shutting it off
bergilong
Postby bergilong » 08:26 pm Aug 08 2017
I drained some gas out by leaning it over and still can't get it to start
bergilong
Postby bergilong » 09:40 pm Aug 08 2017
Okay, I got it to start. After killing it, I was then able to start it first kick. It does just sound like the float was stuck closed. My carb is extremely clean inside. Maybe it just needs a rebuild
bergilong
Postby david » 08:22 am Aug 09 2017
Have you tried a new spark plug? I can let mine sit for months and it will start 3rd kick w/choke, cold.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
david
Postby doakley » 11:49 am Aug 09 2017
Mine is doing this same thing and none of the above fixes has worked. I have to use ether when it hasn't been run for a while. After that first start it cranks first kick every time. Very frustrating. I'm going to change the jet block gasket just on general principles.
Images: 1
Has thanked: 0 time
Been thanked: 27 times
Postby bergilong » 11:38 pm Aug 09 2017
doakley wrote:Mine is doing this same thing and none of the above fixes has worked. I have to use ether when it hasn't been run for a while. After that first start it cranks first kick every time. Very frustrating. I'm going to change the jet block gasket just on general principles.
Yeah, it's really annoying. Let me know if anything fixes it
bergilong
Postby BigH » 08:58 pm Oct 23 2017
I see these posts were from 2016. I now have the same thing. I installed a carb rebuild kit on it. It always started 1st kick unless very cold. I agree very annoying! I have a fmf pipe & silencer, boysen reeds, & stock jetting. plug is still not brown on chop test. Still black but has run pretty well. What jetting are most running. I ride @ 600 to 900ft.
BigH
Has thanked: 0 time
Postby bertos883 » 04:36 am Jan 24 2018
When I had issues starting my '01, I tried a bunch of stuff, but ended up changing the pilot jet from a 48 to a 45. Now she starts easy all day
bertos883
Has thanked: 0 time
Postby ohgood » 03:34 pm Jan 24 2018
Fuel on, choke onlean it over, and cycle the engine 5-10 times to pull fuel into the engine, then kick it.
ohgood
Images: 3
Has thanked: 147 times
Been thanked: 65 times
Return to KDX 200 H series
Who is online
Users browsing this forum: No registered users and 1 guest
