What is the maximum horsepower from a 200/220?
Posted: 03:00 pm Feb 27 2016
Cornishwrecker posted this back in 2009:
"Speed is just a question of money......
How fast do you want to go !
Yep RB head & carb mod will make your kdx run well...... But nowhere near as well as a full port job with added head & carb mods.
My 220 has had a full port job done with the head squished, jetting dialed in on a dyno & running a 36mm carb off a kx 125, boyesen rad valve with modded air box, timing adjusted & all breathing through a full FMF 'woods' pipe...... My bike just puts out shy of 40 bhp at the rear wheel, now you may think that with all these mods my bike runs like a mx bike but you'd be wrong, for the power delivery is very smooth with lots more bottom end pull , a healthy mid range plus a few extra rpm over run ....that's what I asked for when I spoke to the tuner & that's what I got....
So to answer your question .... Go to fredette & get the full works ."
Looks like he has his PMs turned off so I'll throw the question out for discussion:
What is the maximum horsepower/torque that anyone has documented for the 200 or 220? Does anyone have a dyno run chart available? (Be sure to specify which model and what mods you have completed to achieve your results.)
L
L
