it's pretty much the same from startup to whenever. the power is consistantly bad, at every rpm, except one tiny sweet spot while accelerating, around 1/4 throttle. above or below that sweet spot, and it's just crap, sputter sputter cough sputter, etcTedh98 wrote:Does it always run better cold and then get worse as it heats up?
Are you in North, South, East or West part of Alabama?
pulled the pipe to look and see if the piston was split in half or something, and saw the fueling might be off a little:
birmingham, al - kinda in the middle.
if it cured itself tomorrow, and grew an electric starter, i'd have zero desire to ride it at this point. it's just too negative an experience from all the troubleshooting that went no where. the only motivation (which is very little) now is so someone else won't have the same extremely negative experience i have. green isn't pretty anymore.
