Lowering links
Lowering links
Hello, I have a 1999 KDX 200, my bike is a little too tall for me, so I took the link off, cleaned it up and found it is a DeVol Racing link, it look like its adjustable, the holes are 4-3/8" center to center, my question is if I increase the distance between the holes, will it lower my bike?
- IDRIDR
Re: Lowering links
I don't know the answer to your question, but this may help: http://www.koubalink.com/kdxinstall.html
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
2014 Suzuki DL1000.
- 6 Riders
Re: Lowering links
I'm not sure your exact question so...Making the link longer will lower the back of the bike. You must also run the forks up into the trees to compensate on the front.
Lowering links
"if I increase the distance between the holes, will it lower my bike?"
Yes, it will
Yes, it will
Re: Lowering links
Thanks!
Re: Lowering links
Stock length is 112.5 mm (which it sounds like you are at/near), lengthening the link will lower the bike, but will also change leverage ratio, softening the rear end.
