On checking the function of my KIPs it looks like I have a splodge issue. Its opening but taking ages to close. Squirted some spray lube around.
I guess its a pull the top of the motor off to clean it out?
Cleaning my KIPs
Cleaning my KIPs
I do wonder if I can do this with just taking the head off? My top end is fine. Guess I plunk around to much in a high gear in the woods. Looks like mine is not closing.
- scheckaet
Cleaning my KIPs
much easier to take the jug out and clean all of it. put back together and JET your bike properly using the jetting how to. some spoo is ok and normal, a lot is sign of bad jetting.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Re: Cleaning my KIPs
I neee to clean mine too. Which gaskets can be reused? Obviously none that are damaged. My top end was done this winter so they are all fairly new. How much harder is removing the whole jug than just the head?
Cleaning my KIPs
I suspect this has been like this since i bought the bike. It would explain a few things. Yes I have been through the jetting and dropped main and idle jet sizes. Runs much better. I will try to do it with just the head off and see how it goes.scheckaet wrote:much easier to take the jug out and clean all of it. put back together and JET your bike properly using the jetting how to. some spoo is ok and normal, a lot is sign of bad jetting.
Just take the hole thing off. Its four more bolts. Get the cometic gasket kit for 30 bucks and youll have everything even new exhuast orings and every kips gasket
I took the Kips cover off the LH side along with the plug from that side. Quick squirt of carb cleaner and a lot of splodge came out.3j3j3j wrote:Just take the hole thing off. Its four more bolts. Get the cometic gasket kit for 30 bucks and youll have everything even new exhuast orings and every kips gasket
Kips now working as it should. Snaps shut.
Well that was easy!
