Hi guys
I want to swap out my rear brake pads, however one of the pins has been stripped by the previous owner and I've tried drilling etc with no luck.
Do you have any tricks to try before I just drop it in to the shop?
Cheers
tucker
Stuck rear brake pin
- Country: New Zealand
Re: Stuck rear brake pin
welcome
have you tried heat and penetrating oil, too?
Had the same problem with my 89 originally. Buggered it so bad trying to get it out that I ended up replacing the rear caliper.
- 6 Riders
I used an EZ-out. Drilled a pilot hole, then went to the EZ-out. I replaced my pins with the set from rmatv that have a standard hex head.
The pins need to be lubed too.
- Molly's 70
Penetrating oil & 24 hours can do wonder's. Liquid wrench, Kroil, or my favorite, 50 /50 mix of acetone & transmission fluid.
- Tyl3r
Can you put some vice grips on the pin portion, that goes through the pads? Maybe you can clamp onto that and rotate it out?
- Country: United Kingdom
tucker wrote:Hi guys
Cheers
tucker
This guy has great tips.
Sent from my CPN-W09 using Tapatalk
